My 54 needs a new gas tank
#31
To let all my helpers know, I bought a prebent fuel line from Inline Tube following Matt's advice. I am getting the steel line for $45. It comes with the cloth loom.They had a 20% sale so that brought it to $36 plus $8.50 shipping plus PA sales tax. Much cheaper than Mid Fifty or Carpenter.
Thanks for the help so far. There will be other questions I'm sure.
#32
#33
Mine is a Tanks Inc. replacement. I reused my original straps, replacing both bolts with stainless. I used bicycle innertubes for rubber insulators.
The only catch I found is the tank's plumbing was for a newer engine. I had to reduce the pipe size to work with the original style fuel pump intake.
But, Ken, my tank did NOT come with an outlet fitting, just a threaded hole. So on yours you could not use the old one? Did your tank come with a fitting? And you had to buy a reducer?
#34
Abe, I believe my truck uses a 1/4" fuel line, and the tank was tapped for 3/8".
My tank looks like it is a little different. It isn't a true reproduction. Mine doesn't have that bend in the flange, and doesn't have a drain plug. It also had the 90 degree elbow fitting, and an adapter plate for the new-style sending unit.
Yours looks like a true reproduction. You might be okay.
#35
firebirdparts
1999 to 2016 Super Duty
10-26-2019 06:28 AM
notthemaniusedtobe
02-09-2014 10:50 AM
bkr2
12-05-2009 09:14 PM
