Factory fan blade differences
Old Oct 11, 2003 | 04:30 PM
ceetwarrior's Avatar
ceetwarrior
Question Factory fan blade differences
I've been junkyard searching lately and have seen different types of fan blades on 70-72's. They are a 5 blade and 2 of the blades are close together and looks off balance. The blade that is on my '67 is only a 4. Does anyone know the difference between the 4 and 5 as far as air flow is concerned? What about the 5 blade with the 2 offset? Thanks!
Old Oct 11, 2003 | 06:32 PM
Like M. Fords's Avatar
Like M. Fords
I know the 5-blade offset fan came with the FE's and HD radiator. As for what other engines/radiator combinations use them instead of the 4-blade, I am not sure.
As for the reason for the offset, it might have something to do with harmonics/noise. Since these fans were not intended for fan clutches, Ford may have been experimenting with making the fans as quiet as possible. And for the amount of air they pull, they are fairly quiet compared to newer vehicles when their fan clutch engages. I do know that the spacing between blades seems to make changing the belts a little easier.
Old Oct 17, 2003 | 10:44 AM
ceetwarrior
Anyone else got any ideas? LikeM's theory sounds good.
Old Oct 25, 2003 | 04:18 PM
boogity24's Avatar
boogity24
mine has 6 blades.
