Mallory Unilite Dist issues
Old Dec 17, 2019 | 07:36 AM
BayStYat's Avatar
BayStYat
I want to replace my Mallory with a more simple unit. should i go back with points style or HEI? Im am pretty sure this Unilite is causing my issue.
thanks
Old Dec 17, 2019 | 07:54 AM
robertrpeak's Avatar
robertrpeak
POINTS!! what could be more simple?
Old Dec 17, 2019 | 07:58 AM
BayStYat's Avatar
BayStYat
haha,
thanks.
is this ok ?
https://www.ebay.com/itm/FORD-260-28...S/321774159112
or
Amazon Amazon
Old Dec 17, 2019 | 08:09 AM
robertrpeak
https://www.sekotimsale.com/index.ph...ucts_id=462503
Old Dec 17, 2019 | 08:35 AM
BayStYat's Avatar
BayStYat
holy smokes! thanks
Old Dec 19, 2019 | 12:12 PM
Freightrain's Avatar
Freightrain
What is the problem? I run Unilites in a couple of my hot rods with no issue.
I would NOT put one of those stupid GM HEI distributors in one of my vehicles.
Old Dec 19, 2019 | 12:29 PM
ford390gashog's Avatar
ford390gashog
Originally Posted by BayStYat
holy smokes! thanks
fair warning, the seko website is a scam lots of those websites. You won't be getting any product.
Old Dec 19, 2019 | 12:34 PM
BayStYat's Avatar
BayStYat
I seem to have a issue with ignition. Its an older Uniilite. New wires, plugs, coil. I can get it to start, idle and rev but it has a miss, once I put in gear it will die. Its getting fuel because the plugs are fouling.
Old Dec 19, 2019 | 12:35 PM
BayStYat's Avatar
BayStYat
awesome thank you sir
Old Dec 19, 2019 | 02:52 PM
Freightrain
Strange.
Does the miss sound like just one cylinder? You don't mention new cap. Could be cracked or other issue and causing internal misfire.
Have you checked timing yet?
Put the timing light on each cylinder and watch for no light or misfire when you rev it and that would at least narrow down it if it one cylinder. Not saying it can't be electronics, but need to test all output first.
Old Dec 19, 2019 | 03:12 PM
BayStYat's Avatar
BayStYat
Strange.
sorry. New cap and rotor.
I will do that test
thanks buddy
Old Dec 19, 2019 | 04:54 PM
Alex from GA's Avatar
Alex from GA
Stock distributor with a Pertronix points eliminator. Never have to adjust points again.
Old Dec 19, 2019 | 07:02 PM
BayStYat's Avatar
BayStYat
Strange.
please elaborate on using a timing light to find a miss. I am assuming the light will not light up if it has no spark on that wire?
Old Dec 21, 2019 | 01:46 AM
1TonBasecamp's Avatar
1TonBasecamp
Correct. Or will light up, but while watching you will see it act intermittent or otherwise out of synch with what is expected.
You can see a lot of interesting things when you clamp the timing light pickup to each wire. Even just a fouled plug will show up (at least some of the time) as inconsistent flashes with a timing light.
And obviously if one is completely dead, you have a good starting point for the hunt.
Paul
Old Dec 21, 2019 | 11:23 AM
kenny nunez's Avatar
kenny nunez
Mis fire
Yat, If after you have done all the checks there is one other thing to look at.
Remove the valve covers and turn the engine slowly by hand while watching each rocker arm, they should all move the same amount. If you see one not moving as much then you have a worn out cam lobe due to not enough cam lube on the lobes when installing the new cam.
