6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
No cluster no crank
Old Dec 16, 2019 | 10:25 PM
Twinpower's Avatar
Twinpower
No cluster no crank
08 350 6.4. Truck will not crank has no cluster response and will not let ids connect. To date I have had the key transponder replaced ecm and cluster with nothing changing the situation. I do not have the original keys but tried to have keys made which caused the transponder replacement.
at a loss of which direction to go next. Any thought suggestions would be appreciated
Old Dec 17, 2019 | 11:21 AM
projectSHO89's Avatar
projectSHO89
Did you check to see if the PCM is getting operating power and its ground?
Old Dec 17, 2019 | 11:30 AM
Twinpower's Avatar
Twinpower
I am being told yes. The only issue that has been found was a pin coming from the cluster that was supposed to have 1.2 volts but only had .6. So the shop replaced the cluster. They are unable to see the ecm with a scanner but it passes the pin test.
Old Dec 18, 2019 | 03:00 PM
speakerfritz's Avatar
speakerfritz
is this your daily driver that all of a sudden has this problem?
or is this an auction truck that you are now attempting to get runnning?
some history would be helpful....
Old Dec 18, 2019 | 03:45 PM
Twinpower's Avatar
Twinpower
It is a daily driver that on Wednesday ran fine then on Saturday nothing. Other then the anti theft light flashing. No cluster no crank can’t put the gear selector in neutral nothing. However windows radio all accessories work
Old Dec 18, 2019 | 04:18 PM
speakerfritz
I had this happen on my 2010.
it went into thef mode
i had to use two keys to “unthef mode it”
jdscholl
6.7L Power Stroke Diesel
Sep 2, 2021 01:54 PM
finneys98xj
WTB - Ford Trucks & other vehicles
Apr 29, 2012 07:16 PM
boydston58
Electrical Systems/Wiring
Aug 29, 2009 11:21 PM
torchy
2004 - 2008 F150
Dec 11, 2008 11:14 AM
