95 ford f150 300 i6 m5od to np435 swap?
hey guys, today i thought about putting an np435 and rip out that crappy m5od, mainly because i hate the high 1st gear and reverse ratio, im looking at the np435 because of the REALLY low granny 1st gear, and would i need anything else to do the swap? and would a zf5 be any better? thanks
Can you get bellhousings for either?
I have a recollection that the small block and i6 are similar,
but that seems...odd... given the different block shapes.
In your shoes, I use low range around the ranch, which works ok.
3.55 gears in mine, which helps a little.
I agree, the M5's ratios are not meant for a work truck.
t
t
You'll need clutch slave cylinder, throwout bearing, and fork. You should verify the clutch disc has the correct spline count for the NP435. Not sure if they're the same between M5R2 and NP435.
The 300 uses a Ford smallblock bell housing.
ZF5 is another option, but they seem hard to find, at least in my neck of the woods.
t
t
i have stock tires, yes, the truck could also use a new pressure plate
Same here !
lewisriverkid
17
10-09-2019 04:01 AM
ChadR93
11-30-2001 05:30 PM
