2001 B3000 Engine Replacement Options
Old Dec 15, 2019 | 10:10 AM
Erik the Bike Man's Avatar
Erik the Bike Man
I am in need of a new block for my B3000, that's the 3.0L Vulcan.
There's a few options available on craigslist right now, but I'd like some input before committing to anything.
First is this 2011 motor, is this too new? He doesn't say whether it's the vulcan or the duratec.
https://eauclaire.craigslist.org/pts...033668632.html
Then there's this '94 sable motor. It's the right block for sure, but I understand I need to use ranger head gaskets and my existing intake plenum as the thermostats are on opposite sides. Also I ran that VIN and it was totaled in a front end collision in '06, doesn't exactly inspire confidence.
https://minneapolis.craigslist.org/w...016673859.html
Push comes to shove I'll just call up the local salvage yards and find something a little closer to mine.
Everyone I talk to just says to give 'er the old 5.0 swap. But I just want my little truck back!
Thanks.
Old Dec 15, 2019 | 11:03 AM
Conanski's Avatar
Conanski
You can use any 3.0 vulcan up to 2008, but the 2000+ Ranger/B3000 motors will be the most direct swap.. earlier Ranger/B3 motors have a different intake and wiring and everything external of the longblock will be different on the car engines.
Old Dec 15, 2019 | 12:10 PM
Erik the Bike Man
I am prepared to strip the sable engine down to the block and reuse everything off of my existing engine. I am wondering if there's anything I should be concerned about if I go with a block so much older.
So that 2011 is a duratec then.
Old Dec 15, 2019 | 02:37 PM
Conanski's Avatar
Conanski
The '94 motor won't make as much power as the one you had but should otherwise be fine, and yeah the '11 is going to be a Duratec which is a complete no go.
Old Dec 16, 2019 | 07:30 AM
Erik the Bike Man
Is the block/head any different? I was under the impression that the main power bump for these engines over the years came from the intake and exhaust, which I will need to salvage off my old engine anyway.
I'll probably call the guy about it today.
Old Dec 16, 2019 | 10:30 AM
Conanski's Avatar
Conanski
I'm not aware of any block or head differences. At one time we had a 94 and an 04 Ranger here both with the 3.0 and there was a significant difference in power, I know the intakes were different but it felt to me like there was enough difference that there had to be more too it than just the intake.
Old Dec 16, 2019 | 08:22 PM
Erik the Bike Man
Research tells me they changed the cam timing in 1998 for a few more horses. I'm in no rush, I'll keep looking for the correct configuration then.
Old Dec 28, 2019 | 11:40 PM
Erik the Bike Man
Just a follow up.
I chose a reasonably priced engine from a 2006 Taurus, 86k miles. Everything went smoothly, stripped it down, swapped in ranger head gaskets. I had to press in and weld on a ranger oil pump dip tube, salvaging mine wasn't an option, the failed rod mangled it pretty well.
I left the taurus timing cover in place, part number nearly identical (revision B, ranger (2001) is A) and didn't see a reason to change it out.
Some say the taurus cam is different, maybe but I didn't want to use that from my blown engine.
The only modification I had to make was to the flexplate as the hole pattern is different. Two holes required relocation as the pattern is asymetrical. It's a shame it didn't occur to me to take pictures, but I was freezing my *** off the entire time.
Maybe it's because I haven't driven it in so many months, but it seems this engine idles way smoother than the old engine.
Jeffery Carter
Sep 27, 2016 06:49 AM
raittig
15
Apr 7, 2013 03:00 PM
Benaghetto
37
Feb 18, 2008 02:12 AM
mustanginca
Dec 24, 2007 03:17 AM
Koger
May 14, 2005 10:58 PM
