Bad mpg
Old Dec 15, 2019 | 04:10 AM
Korbin's Avatar
Korbin
Bad mpg
I have a 1980 4x4 5.0 np435 and I’m struggling to get 4 mpg driving careful. It has new plugs and wires, distributor cap, ignition module, air filter and pcv valve. None of these things were an attempt to fix gas mileage but just cause they were bad. I’ve read threads of guys with the same setup getting 14 mpg. What are some things that could cause this?
Old Dec 15, 2019 | 05:06 AM
Kramercd's Avatar
Kramercd
What's your method for calculating fuel economy? I'd imagine if you were getting four miles a gallon you'd be able to taste the fuel coming from the exhaust inside the cab while driving 60mph into a headwind.
What size tire, how aggressive the tread? What ratio is in the front and rear end. Are you driving in 4x4 all the time, as in your stuck in 4L and the hubs haven't been unlocked since '82. Brakes drag? How much additional weight is on the truck? Haul a lot of tools and gear? Is your timing way retarded and the carb set pig rich? How well does the truck run? Is this a daily driver or does it set for awhile? What's the likely hood you have a leak in your tank. The gas is evaporating or being siphoned from the bowl vent on the carb or boiling out in the desert heat?
Lot of things can affect fuel economy. Got a picture of your truck and your engine bay just so we can get a rough idea of what we're looking at?
While you wait for the others to wake up, start reading this thread, it has a lot of good fuel economy info.
Old Dec 15, 2019 | 05:37 AM
Rembrant's Avatar
Rembrant
I was going to say the same. At 4mpg, the fuel should be pouring out of the tailpipe.
Is this truck a short box or long? Reg cab or extra? Lifted or stock height? Are the tires stock size (and if so which)?
Old Dec 15, 2019 | 05:49 AM
FuzzFace2's Avatar
FuzzFace2
That is all good and needs to be checked but if the speedo and mileage are not spot on you can get 4 mpg or 25 mpg.
Dave ----
Old Dec 15, 2019 | 06:56 AM
LittleBlue79's Avatar
LittleBlue79
I had have to guess that your odometer must be reading wrong for some reason. I can't imagine a 5.0 getting that kind of mileage for any reason other than a massive fuel leak.
My 79 with a 7.5 auto and 4x4 averages 12mpg if I drive careful, 8mpg if I decide to burn rubber at every red light.
My 84 with a 5.8 manual and 4x4 averages 12 mpg so far (have only had it a few weeks) and it in fact does have a fuel line leak, slowly dripping in my driveway. AND runs extremely rich at idle. So it should go up to that 14 maybe 15 number once those issues are addressed.
I can't imagine any reason why the engine is actually consuming that much gasoline.
Have a bad manual fuel pump and gas is getting into the crankcase? If the diaphragm is damaged it will pump fuel straight into your oil.
Have any fuel leaks?
Use a gps to make sure odometer is counting correctly, I've seen some that even though the speedometer is accurate the gears in the odometer miss every other tooth.
Old Dec 15, 2019 | 07:00 AM
Tedster9's Avatar
Tedster9
Mileage may be poor, though 4? There is an air fuel ratio limit at both ends of the spectrum, too rich and the plugs won't even fire. When they are dripping black you're gettting close.
Old Dec 15, 2019 | 04:58 PM
Korbin's Avatar
Korbin
I will for sure use a gps to check it again I’m driving in 2 hi for sure. It does struggle to go 65 mph but it will do it. Nothing getting into the oil and it does smell like crap while driving. I’ll have to check the gearing to see what it is. I’ll try and check if the fuel pump is bad. Brakes aren’t dragging and if they are it isn’t noticeable driving it coasts pretty well. I’m not carrying any tools are gear. The timing is advanced by like 5 I believe. Thank you guys for the great response. I’ll keep this updated till I figure it out.
Old Dec 15, 2019 | 07:07 PM
Franklin2's Avatar
Franklin2
Timing should be at least around 10 BTDC.
Old Dec 15, 2019 | 08:20 PM
Kramercd's Avatar
Kramercd
Are you still running the stock carburetor and how long since it's been rebuilt or at the very least retuned? Is the vacuum advance on the distributor still hooked up and working?
Old Dec 15, 2019 | 10:55 PM
LittleBlue79
I agree with Franklin2. You should definitely get that timing into spec.
Can you define smells like crap? Burning oil? Running rich?
Do you have a tach? What rpm is the engine at when driving at 65mph? IMO around 2200-2500rpm would be healthy for mpg.
DLTtoday
2009 - 2014 F150
25
Sep 10, 2013 11:52 AM
Davidvc1964
Jul 5, 2013 02:59 PM
Bayer-Z28
May 11, 2010 10:16 PM
tjc transport
29
Jan 13, 2009 08:18 AM
Deuce45
Jul 28, 2008 04:03 PM
