Plasma Cutters
Old Dec 14, 2019 | 11:11 AM
jimmystoys's Avatar
jimmystoys
Plasma Cutters
Hi all. Was interested in cutting some metal. I can't see any more than about 1/2" thick, probably thinner than that most of the time. Plasma seems to be the more modern way? Anyone have any thoughts or advice? Thanks.
Old Dec 15, 2019 | 05:55 AM
tjc transport's Avatar
tjc transport
i ain't rite
for constant use, go name brand. of once in a while use, the harbor freight unit is fine. mine is about 15 years old now and i can not imaging going back to using a cutting torch after using the plasma cutter.
Old Dec 15, 2019 | 07:51 PM
jimmystoys's Avatar
jimmystoys
That's good to know Tom, thanks. I'm glad you chimed in here. I've been thinking of getting a cutting torch, but think the plasma is the way to go nowadays. Cutting torch, maybe for heating up metal and bending it if I need too. Still hoping to hear more ideas...
Old Dec 15, 2019 | 07:57 PM
yby's Avatar
yby
Following...
Old Dec 16, 2019 | 04:35 AM
tjc transport
i ain't rite
there are some places a plasma cutter will not work and a torch is needed, but i try to stay away from that kind of work anymore.
since i am now older than dinosaur dung, it is getting harder to do the heavy stuff.
Old Dec 19, 2019 | 07:41 AM
Benztechnc's Avatar
Benztechnc
AM I right in thinking with a plasma cutter you also need to have a good air compressor. If so what size would you suggest?
Old Dec 19, 2019 | 08:07 AM
ford390gashog's Avatar
ford390gashog
I suggest not buying a transformer based machine. Make sure you get a machine with pilot arc for cutting rust. I suggest looking at the Everlast or Alpha machines. The plasma vulcan from harbor Freight is due out in January but I believe that may end up being a very expensive plasma cutter. You can plasma with a 6 gallon compressor just fine. It's not like air arc gouging with huge cfm requirements.
Old Dec 19, 2019 | 10:28 AM
tjc transport
i ain't rite
i use a 240 volt HF plasma cutter and a 60 gallon tank air compressor.
i can cut 1/2 steel with no problem. as for compressor size, it is the primary air for the shop.
Old Dec 20, 2019 | 12:16 AM
jimmystoys's Avatar
jimmystoys
So gashog, cutting rust requires special plasma setup? Transformer based machine, pilot arc, what's the difference?
Old Dec 20, 2019 | 10:17 AM
ford390gashog
Yes people don't realize that lots of plasma cutters are scratch start. This kills productivity and makes for a terrible experience along with burning up torch consumables. If you are cutting and encounter rust or anything else that causes you to lose the arc you have to start over. With pilot arc you can set the pilot delay which will maintain the arc through most rust and allows you to start in confined areas like you would with a torch. You will find pilot arc in most mid priced machines, I suggest only looking at inverter machines as they are the most versatile in terms of features and flexibility with voltage.
Old Dec 20, 2019 | 05:28 PM
tjc transport
i ain't rite
my HF unit is not scratch start.
Old Dec 21, 2019 | 11:37 AM
jimmystoys's Avatar
jimmystoys
Very interesting. I'm learning something all the time on this forum. Thanks again gashog. I hope there's still more advice to share out there...
Old Dec 21, 2019 | 12:55 PM
ford390gashog
Correct, that unit is a inverter machine with pilot arc. It's a good machine that uses P40 consumables. I have been waiting for the Vulcan Pro Plasma to arrive.
DeeDubz
Garage & Workshop
Feb 19, 2018 08:36 PM
SSSimon
Australia Chapter
Apr 16, 2014 12:29 PM
Stephen67
17
Aug 4, 2012 11:57 AM
19fifty4
22
Dec 19, 2008 12:30 PM
Duke78
Paint & Bodywork
Mar 19, 2008 06:01 PM
