Correct PCV Valve?
Replace cracked exhaust manifold - Check
Replace fuel pump - Check
Replace brake lines, MC, WC and rebuild all four drum brakes - Check
So close to getting it back on the road and out of no where the engine starts running rough. With NumberDummy's help i was able to find the correct replacement Distributor Advance Canister which helped a little but it's still running rough.
I've checked for vacuum leaks multiple times with propane and starter fluid and found nothing. After some research on this forum I wanted to check my PCV valve to see if it was functioning correctly. Every post/video/part I can find shows a EV49B PCV valve pushed into a rubber grommet in the valve cover but sure enough like almost everything on this truck mine is different. So different i cant find any pictures etc that match.
Can any one identify this PCV valve, what the part number is, and how it is replaced? Or should i pull this valve out and install a grommet and EV49B?
The grommet is available, too, if it tears. Use care if the hose runs to an original carburetor spacer. Those are getting near impossible to find.
I have to say though, that I believe that any of them can eventually wear out to the point that the parts are no longer good. If it still uses what is called the "pill" inside, all that banging around for 50 years or more can take it's toll. On anything!
Hence my recommendation of trying a new one anyway. Nothing as cool as old-school, and nothing old-school as cool as original! But at some point, you might still have to let go.
Another test might be to pull the hose off of the top and simply plug it to see how the engine runs. Yes, the overall fuel/air mixture will have changed, but it should still run and you can note the difference in how good or bad it runs with the valve out of the equation.
Good luck!
Paul
I don't have time right now but when I get a chance I'll take both of these apart and show what they look like inside.
Here's a used one for $225 asking
https://www.ebay.com/itm/1965-1966-F...UAAOSwHfZdF6lN
Here's an NOS one for $350
https://www.ebay.com/itm/NOS-1965-66...8AAOSwbw1aAlli
And you thought I was just kidding....
I posted a couple of very expensive originals in the post above, but if you put a search on eBay they do show up for much better prices occasionally. Here's one I bought in the Ford box (AC Spark Plug Type) for under $20 before tax. Says it is for a 170 but it was also used on other engine sizes including 289 like in a Mustang and 300 6-cylinder.
C5TZ-6A666-A - VALVE - POSITIVE CRANKCASE VENTILATION (P.C.V.)
https://www.ebay.com/itm/NOS-1963-19...53.m2749.l2649
The 352 used a slightly different design, but looked very similar with the hex shape to it.
In fact, the "rattle test" is the tried and true method for making sure yours is still functioning. Personally I will use the rattle test, but only use it so far. If a valve looks gummed up and old, but still rattles, I've found replacing it to be the best practice. They're cheap!
If not in a place to replace one immediately however, some carburetor cleaner to soak it up and clear out some of the gunk will extend the life of a PCV valve sometimes fairly long.
Paul
It may have the incorrect valve which will most likely throw the fuel trim off
1965 F-100 I6 300 ... ??? ...
Below is a Motorcraft EV49B Valve
They can be a little tricky, especially on custom built engines. If not matched to the engine "needs" they don't suck enough to sweep the crankcase or they suck too much and foul the intake and combustion chambers. Doesn't hurt to keep an eye on things for a little while after installing a pcv valve to make sure it's working with the engine and not against it.
There is an adjustable valve that will enable one to continually tune the system..
Oh well, basically just saying what KULTULZ said but with twice the number of words...
The reason I changed mine originally was so I could plumb it more cleanly with stuff I had on hand. Bending my own metal line, and terminating it at each end with rubber hose.
For that I needed/wanted a valve with a 90° 3/8" barb where the stock Bronco valve was straight up and required the hose make the 90. No problem for the molded factory hose, but not what I wanted.
The first one I tried was for a '75 Ford Grenada with 302. This was for my stock 302 so I figured it would be a good fit. WRONG! That's the one that acted like a big vacuum leak. Figured that it was due to the smog calibration for a '75 vehicle vs my pre-smog '71. Made sense to me at least.
The one that I finally settled on was from a '72 Corvette 350ci engine. When I tried it on for size the engine ran just like it did with the stock one. So I figured the calibration was very close to my original.
So that's what I ran in my Bronco for the next twenty years or so. Kept the Grenada unit in my tool box for those high-altitude excursions.
Paul
You feeling OK ...
