Rocker arms worth it
Old Dec 11, 2019 | 02:20 PM
89 flatbed's Avatar
89 flatbed
89 f250 7.5l efi, considering how poorly the heads flow on these engines, is it even worth it to up the rocker ratios to cheat a little lift and duration out of my valve train? It's pointless if the lift and duration gain exceeds the efficiency of the heads just don't know if that's going to be the case or not. Anyone have any experience on the topic?
Old Dec 16, 2019 | 01:24 PM
monsterbaby's Avatar
monsterbaby
honestly in a stock or nearly stock engines messing with rocker ratios is a waste of money.
Old Jan 3, 2020 | 09:38 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
Your money will be better spent trying to get it performing better, make sure everything is spot on. like everything, fuel pressure, timing, spark plugs, exhaust restrictions, and get the exhaust flowing, the intake working, and the ignition system tuned in, cap rotor, plugs wires o2 sensor, If you suspect engine issues.... rebuild it.
89 flatbed
Dec 13, 2019 12:03 PM
Uncle Grumpy
Mar 11, 2012 07:21 PM
jazzy66
Jan 13, 2005 06:36 AM
76 F250 4X4
Oct 16, 2004 12:40 AM
big_beast302
Apr 8, 2003 09:45 AM
