Sponsored by: Real Truck
2000 f3507.3
Old Dec 9, 2019 | 10:11 PM
Theword's Avatar
Theword
2000 f3507.3
Hello everyone. I have been racking my brain for a while now. My truck has 267,000 miles on it. The issue that I have been having is that the driver side injectors are not working. There is white smoke coming from the exhaust. I did replace the valve cover gasket. I did ohm all injectors on the driver's side. They were at 2.8 ohms. When I unplug the driver's side the engine runs smoothly. I know the injectors are not working due to the fact that I have an exhaust temp gauge on the driver's side. I did hook up a snap on reader and with the test koeo cylinder Ballance test there were codes for cylinder 2 4 and 8. But not the common one for the wiring. The other issue is that both of the glow plug and intake heater solenoids are not working. I have power from the small red wires but it seems that from the purple wire there is no ground to create the circuit. Has anyone had this issue and what should I look in to? Thanks for any advice.
deshet1980
32
Mar 25, 2017 03:22 PM
mylakers
41
Nov 11, 2016 05:13 PM
NorthernWild
18
Aug 19, 2014 01:05 AM
Bergerson
13
Apr 27, 2008 11:00 PM
Islander1
Mar 29, 2008 12:06 AM
