1991 E40D no first gear...
Old Dec 16, 2019 | 07:22 PM
Paul 92 f350's Avatar
Paul 92 f350
You can check all the grounds at pcm while its unplugged too. Hopefully someone has the right diagram. I found this much easier after I took the whole harness apart under the truck. You can check your mlps there too.
Old Dec 16, 2019 | 08:24 PM
Dan Niksich's Avatar
Dan Niksich
Guess I'll pull the computer and check it out. Hopefully I find something obviously wrong. This is driving me crazy. I'll look around for a diagram now.
Old Dec 16, 2019 | 08:40 PM
Paul 92 f350
Mine drove me crazy too! I know alot more than I did though. Lol. You can get a computer at the wrecking yard cheap if you can find the right one. Where you located?
Old Dec 16, 2019 | 09:10 PM
Dan Niksich
Gary, Indiana
Does it have to be from a 91? Or are there interchanges?
Old Dec 16, 2019 | 11:03 PM
Dan Niksich
I found one for a 90. Guess I can matchup wire colors to see if it's the same.
Old Dec 16, 2019 | 11:38 PM
Paul 92 f350
Solenoids signal and power appear to be the same as the one I sent so maybe those are standard. I wouldnt think there would be many configurations to the boards.
Old Dec 17, 2019 | 12:17 AM
Dan Niksich
I'll be checking it out in the morning and hopefully I find something out of whack. Not much more it could be at this point I'd guess. Did you see my reply about getting 3.4v on the "D" terminal of the ecc relay when unplugged when I'm supposed to get none? What could cause this? And could this be a problem?
Thanks for the help.
Old Dec 17, 2019 | 11:04 AM
Paul 92 f350
The reason I say to put a jumper wire across the relay is so you can isolate that circuit and run your tests with key off. Thought I would clarify. This ended up being the easiest way for me to check everything with the pcm out of the loop. Did you ever ground solenoid 1 and 2 manually to make sure your trans shifts? Good luck.
Old Dec 17, 2019 | 11:18 AM
Paul 92 f350
I give credit to FORDF250HDXLT for most of the help and diagrams I have. Thanks again
Old Dec 17, 2019 | 11:35 AM
Dan Niksich
Thanks to both of you for helping! I didn't try manually shifting with a jumper, actually didn't know I could until now but I pulled the ecm and found this. So I'd guess that's the problem.
Old Dec 17, 2019 | 11:37 AM
Dan Niksich
Now I'm trying to find a interchange list so I know what to look for that would fit.
Old Dec 17, 2019 | 12:47 PM
Paul 92 f350
This is where I got mine. It was plug and play. $225 with $25 core charge included. Got it fedex with in a few days. I just kept my core. By the looks of yours it may be junk. He can tell you which numbers to match or you will see it on his website. If you have a good wrecking yard you may find one. I would still test continuity and voltage on all wires in question so you dont fry another one.
https://www.ebay.com/usr/pro-rebuild
Old Dec 17, 2019 | 01:05 PM
  #28
Dan Niksich
Thanks, I will check that out. I'll check the wires like you said just in case. I'm assuming the wires that crossed on the plug from my first post probably caused this but better safe than sorry.
Old Dec 17, 2019 | 03:45 PM
  #29
FORDF250HDXLT's Avatar
FORDF250HDXLT
Yeah, I think it's safe to say you've found the problem. Some people attempt to repair them and just replace those blown capacitors too. So that explains the back feed of a small amount of voltage, coming back up the line evidently.
Old Dec 17, 2019 | 06:11 PM
  #30
Dan Niksich
I was actually half tempted to try it myself. I was thinking the same about the voltage. I'll post again the results but like you said, I'd think this was the problem. Thanks to you both for the help!
