I have a 84 f250 2wd 6.9 C6. looking for a 4x4 chassis to put my clean body on. I know that 80 through 86 would be ideal, but are there other other year chassis that would work? with out any major surgery.
Thanks, Joe.
What is your goal? 4x4? That cab will fit on a f150 chassis also. Do you want to keep your engine or use the engine that comes with the chassis? If you want to use the 84 frontend and bumper, you will need to stay 1986 down. The very front of the frame is different 87-up.
You will have to stay with a f250 or f350 since you want to keep the diesel. Unless you want to modify the front of the frame, stay with 86-dwn. You could convert the frame you have to 4x4. You could use a kit like in this link https://www.skysoffroaddesign.com/co...ford-fsrob-002
The kit will give you all the brackets and mounting points your 2wd drive frame doesn't have. Then if you could find a 85.5-up dana 60 front axle, and a 4x4 trans and transfer case for a diesel and swap that in, you would have 4x4 with your frame you have now. The kit will lift the truck 2 inches.
