Sponsored by: Real Truck
Fuel issues
Old Dec 7, 2019 | 08:45 AM
al4464's Avatar
al4464
Fuel issues
A while back I posted about engine shutting down while driving. Well that problem seems to go away however it has reared its ugly head. 2003 Ford F-250 4x4 v8 gas with extra doors. I could be sitting there idling for a few minutes and all of a sudden it will start idling rough then kill. I will try to restart and it will turn over like normal but no kind of ignition. I will keep trying with the same results. If I let it sit for a couple minutes then turn the key on momentarily then try it will start right up with no miss or nothing. One other thing it will do it while I am driving too with the same results. That is at less the half a tank. I will fill it up and it will stop. Like an old truck it has its issues. When I adding gas the hoses leak a little bit. On top of the tank and the hoses between the tank and the gas cap. I am fixing to pull down the tank and get the hoses corrected. Any other suggestions?
67 StylesLide
Jul 28, 2019 09:56 AM
GoSkins
Feb 20, 2011 07:26 AM
Hybris
1997 - 2003 F150
Aug 23, 2010 03:45 PM
lukebbb
Dec 14, 2008 10:59 PM
bongogirl
15
Mar 12, 2006 02:49 PM
