TPMS sensor reads low
Old Dec 5, 2019 | 04:13 PM
Kdawg89's Avatar
Kdawg89
They all pretty much look the same. But you can see on this one that the sensor hole is not really related to where the air inlet holes are.
https://www.extremeterrain.com/tpms-...product_pics-0
Old Dec 5, 2019 | 04:21 PM
sbrennan007's Avatar
sbrennan007
@SNOW_F350 I'm surprised we haven't come across each other while out plowing... I noticed your Avatar license plate...
Snow Plow Command Truck
Old Dec 5, 2019 | 04:24 PM
sbrennan007
Thanks for the pic, I see what you mean there about where the pressure sensor inlet is at vs. the air intake for the wheel.
Old Dec 6, 2019 | 08:22 AM
SNOW_F350's Avatar
SNOW_F350
With a manual gauge it reads 60 PSI, on the dash it reads 47.
Have you checked the pressure in all four tires yet?
Nothing has changed the suspicion that you're chasing low pressure on the wrong tire. Don't care which one the dash says is low, which tire is really low?
Old Dec 6, 2019 | 09:23 AM
Kaadk's Avatar
Kaadk
The relearn process he said he did in his first post would have addressed that.
Old Dec 6, 2019 | 11:18 AM
SNOW_F350's Avatar
SNOW_F350
That the relearn was successful or wheel positions done in the correct order are huge assumptions based on data to date. It's easy to check all four tire pressures.... Then one would know for certain.
Old Dec 6, 2019 | 11:52 AM
HRTKD's Avatar
HRTKD
If the truck had the wrong positions of the sensors then the relean would have corrected that. When I rotate tires, my truck figures out the correct positions on its own without a relearn.
Old Dec 6, 2019 | 12:49 PM
Sport45's Avatar
Sport45
I’d check all four just the same. It’s a very easy way to eliminate (or confirm) one possibility.
1999-F150
Escape & Escape Hybrid
Apr 5, 2019 08:58 AM
43defence
Aug 14, 2017 08:27 AM
Dogmann
Dec 18, 2013 05:42 AM
itry2fly
Jan 10, 2013 07:29 PM
wahl7s
Apr 26, 2011 03:31 PM
