460 engine build
Old Dec 3, 2019 | 03:31 PM
Mad Hatter's Avatar
Mad Hatter
460 engine build
So im building a 460 for my pickup im getting a new block out of a later model efi truck was told those were roller. But my big question is i have a set of 70 dove 429 heads already with the skrew in studs and high rise intake runners. Would it be beneficial to keep my stock heads or go with the 429. I know they have a smaller cc and bigger intake runners but the valves are the same size I believe
Old Dec 3, 2019 | 03:34 PM
JP3's Avatar
JP3
No 460's were ever roller and it's a pain to use a carb intake with the efi heads.
Old Dec 3, 2019 | 05:56 PM
RalphXL's Avatar
RalphXL
EFI intake to carb kit.
Price Motorsport
Part No. CA-460EFI-HP
Includes two gaskets and (8) 14mm Brass plugs. Suggested for Larger carbs such as 750. 1 3/4” bore $137.50
Jess
Old Dec 3, 2019 | 06:00 PM
RalphXL's Avatar
RalphXL
Your older heads will probably need hardened exhaust seats. I think that hardened seats started with the D3 heads. I'm not sure what you plan to do with your truck, but the stock EFI motor with a cam, headers, and that carb adapter thing I posted above would make a nice combo.
Jess
Old Dec 4, 2019 | 07:40 AM
460me's Avatar
460me
They put hardened seats in my 79 d3 heads. You could see where it was getting mushroomed out
Old Dec 4, 2019 | 11:29 AM
somethingclever's Avatar
somethingclever
E6's should have hardened seats.
Still, not very much money to add them especially if one needs a valve job anyway.
I would utilize whichever heads give me the desired CR if you are not replacing the pistons.
DrZoom
Ford Truck Parts for Sale
Oct 15, 2015 03:47 PM
460plowtruck
May 22, 2013 12:20 AM
atomicjoe23
Aug 18, 2010 09:37 PM
kettle-one
May 5, 2009 07:28 PM
jab55
Apr 20, 2008 02:18 AM
