Tow capacity
Old Dec 2, 2019 | 08:11 PM
Frank79's Avatar
Frank79
Tow capacity
If I am reading this chart correctly, the maximum load I can haul (trailer and contents on trailer) is 12,500 lbs?
Truck is a 4x4 w/ 176" wheelbase. 6.7l, and 3.31 rear end.
Old Dec 2, 2019 | 08:13 PM
Knoxp's Avatar
Knoxp
I am interested in the reply....
Old Dec 2, 2019 | 08:22 PM
drjcw24's Avatar
drjcw24
That's only if your truck has the 68 D 9900 GVWR package. It's basing your max tow weight on a 10% tongue weight for payload purposes, to keep you under the "paper" legal limit of 9900 GVWR, if that makes sense.
Old Dec 2, 2019 | 08:29 PM
Frank79's Avatar
Frank79
It doesn't. Can you elaborate?
Truck was registered as a 9900 GVWR package, that I know.
Old Dec 2, 2019 | 08:35 PM
h20camper's Avatar
h20camper
What’s the gvwr on the white door jam sticker? Post it if possible.
Old Dec 2, 2019 | 08:40 PM
Frank79's Avatar
Frank79
Old Dec 2, 2019 | 08:43 PM
h20camper's Avatar
h20camper
So your truck is rated for the line below. 13,200. Can’t speak about the 9,900 registration.
Old Dec 2, 2019 | 08:45 PM
Frank79's Avatar
Frank79
How did you come up with that? Can you post the math formula
Old Dec 2, 2019 | 08:51 PM
h20camper's Avatar
h20camper
Based on the graph you posted. Line you highlighted has the 9900 package footnote. Your door jam sticker states 10,000. Can you share a picture of your trucks rear differential cover? Axle code 31 might mean you have the Dana rear which you be the heavy capacity tow package.
Old Dec 2, 2019 | 08:53 PM
Frank79's Avatar
Frank79
Id have to take it tomorrow. I dont think I have the Heavy Cap tow package. The hitch is only 2.5"..
What would the differential cover look like for standard package VS heavy tow package?
Old Dec 2, 2019 | 08:57 PM
h20camper's Avatar
h20camper
The HCTP comes with the Dana 275 which rear diff cover has a fill plug on it. The Ford Sterling does not. Its fill plug is on the side of the diff housing.
Old Dec 2, 2019 | 08:58 PM
Frank79's Avatar
Frank79
So it'll be either on the passenger or driver side of the rear differential?
Old Dec 2, 2019 | 09:06 PM
h20camper's Avatar
h20camper
Just look at the rear cover.
The rear axle code of 31 just means 3.31, non-limited slip/locker.
Old Dec 2, 2019 | 09:11 PM
h20camper's Avatar
h20camper
Here’s the Dana cover.
Old Dec 2, 2019 | 09:12 PM
Frank79's Avatar
Frank79
Just took these. Even though its cold here in FL lol lol..
