i have a 2008 E350 with a 310hp 6.8l V10 2-valve engine, the engine is blown.. i have a 362hp 6.8l V10 3-valve engine out of a super duty, the engine is good.. i want to put the 3-valve motor in the E350, can i flash the E350 PCM to run the 3-valve motor or do i even need to flash the PCM?
Due the sensor array of the 3V it would not be compatible with the 2V wiring & PCM. Wiring connections to those sensors, the COP's and injectors would also not be the same between the two different series.
There was a reason Ford never put the 3-valve in the E-series chassis. What that reason is? I don't know. But beware, that reason may pop up in mysterious ways.
The E-series 2-valve uses a different oil-pan than the 2-valve F-series. Does the 3-valve have a different pan layout? Can an E-series 2-valve pan be used on a 3-valve, along with the oil pump pickup (which is also different) ?
The E-series I believe also uses a different oil cooler adapter, which I think puts the oil filter in a different location. Can that 2-valve oil cooler adapter be used on a 3-valve? All these questions would need to be answered before I would even THINK of using a 3-valve in an E-series.
It could also be something as simple(ish) like the throttle body sticks up too far to fit in the engine bay.
