Sponsored by: Real Truck
Intermittent Power Loss
Old Nov 30, 2019 | 03:52 PM
CP7.3's Avatar
CP7.3
Hey guys first time posting here, I have an 02 7.3 PSD with 140k miles. I've been having intermittent power loss. It starts fine and runs strong at times then you can feel the power just drop out to the point where it will barely maintain the speed limit. Even idling it will randomly misfire/run rough. I've replaced injectors, ebpv delete, IPR, CPS, ICP, Engine oil temp sensor. I just bought an Auto Enginuity and got a P1247 Low Boost Pressure code. At this point I'm stumped but think it may be something in the wiring harness/UVCH
Mods: PHP Hydra Chip, 4" Exhaust, Bellowed Up-Pipes
Old Dec 1, 2019 | 11:34 AM
bwguardian's Avatar
bwguardian
Check the wiring harness above the drivers side valve cover before it goes into the 42 pin connector as it may be rubbed through and grounding out. Clear the code and see if it comes back as that sounds like another issue.
Old Dec 1, 2019 | 11:41 AM
CP7.3's Avatar
CP7.3
Sounds good I will check that out
Old Dec 2, 2019 | 11:26 AM
alloro's Avatar
alloro
A plugged exhaust will do this.
Old Dec 2, 2019 | 11:28 AM
CP7.3's Avatar
CP7.3
I just installed new 4" exhaust and bellowed up pipes
Old Dec 2, 2019 | 11:30 AM
alloro's Avatar
alloro
Did you leave a rag inside of it?
How about fuel pressure, have you tested to see if it's low or intermittent?
Old Dec 2, 2019 | 12:17 PM
CP7.3's Avatar
CP7.3
Hopefully theres no rag inside it👉 and I havent checked fuel pressure yet, I got a rental fuel pressure gauge from the auto parts store but it didnt have the right fittings. Is there somewhere on the fuel bowl I can hook up a gauge to test fuel pressure?
Old Dec 2, 2019 | 12:18 PM
CP7.3's Avatar
CP7.3
I think checking the fuel pressure should probably be my next task
oldbandvan
13
Aug 2, 2018 03:45 PM
jay11166
Aug 22, 2015 10:30 AM
danimalmanimal
22
Oct 24, 2011 07:52 PM
Second Image
30
Aug 23, 2008 10:01 PM
JPLTrucking
Jan 10, 2008 08:16 AM
