Engine Romping, No Power
Old Jan 9, 2008 | 06:15 PM
JPLTrucking's Avatar
JPLTrucking
My buddys 02 F350, 7.3, auto, 66 K, has had this strange thing happening once in a while. The trucks engine will start running extremely rough, almost Romping, and he will have no power. The fastest it will go is 3-4 mph, and it sounds like crap when it does. He has replaces the CPS and a trans sensor at the stealership. He also had the #8 injector replaced. Still it does this. Anyone have any ideas?????
Old Jan 9, 2008 | 06:20 PM
ron's power stroke's Avatar
ron's power stroke
did they look at the harness to and under the valve cover??? any SES light???
Old Jan 9, 2008 | 06:26 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
like Ron said check UVCH harness, and make sure check the harness thet goes over the VC for any rubbing and cut wires, cause this seems to be a problem too on some trucks.....
Old Jan 10, 2008 | 07:49 AM
JPLTrucking
Check engine light comes on when its doing it, but goes off when it starts running better. No code comes up when checked after.
Old Jan 10, 2008 | 08:16 AM
ron's power stroke
if there was a SES light..then there is a code..what are you useing to read the codes with??
