Brake controller message
Old Nov 27, 2019 | 03:47 PM
travlingman's Avatar
travlingman
When I hook up my 5th wheel, I always use the manual lever and check the brakes working. The message comes up and says "gain 9, no trailer connected." I usually hit the brake a few times, and pull out. When I pull out the message will come up with my trailers name as connected. The last few times I noticed no message of connected comes up. If I go to trailer set-up screen it shows my trailer as connected. The light check shows all lights good. If I tap brakes all lights work. But, pull manual lever and it shows no trailer connected.
Why would it show this message if trailer connected and lights work, manual lever applies brakes? Any ideas or take to dealer and have cheked?
Old Nov 27, 2019 | 06:11 PM
senix's Avatar
senix
You may have a grounding issue. If under warranty I would snap a pic of the message and take it in. Otherwise look at the truck side connections at the plug in. Maybe wires that are look for the pins.
cgm73
Oct 13, 2019 07:35 AM
Br5ck
Jun 5, 2019 01:39 PM
Greg5OH
Feb 13, 2013 12:33 PM
captnko
May 29, 2012 06:08 PM
Old Fudd
All Things Towing
23
Feb 25, 2012 07:09 PM
