4" lift, what else to replace?
Old Nov 27, 2019 | 11:11 AM
niskyne's Avatar
niskyne
I'm planning to install a BDS 4" lift on my 2014 f150 with 60k miles, it's also had 2" spacers front and AAL in the rear since 10k miles. Since the suspension will be disassembled anyways, what else should I change as routine or preventative maintenance? I'm paying a mechanic to do the lift. Thanks you all.
Old Nov 27, 2019 | 08:34 PM
steve(ill)'s Avatar
steve(ill)
really should not need much new at 60K miles..
check brake pads and discs....... change axle gear lube.
4tl8ford
32
May 29, 2014 11:02 AM
old_lynrd
Feb 20, 2011 08:09 PM
Louie3
21
Nov 19, 2008 10:40 AM
