Sponsored by: Auxito
Fuel tank replacement
Old Nov 26, 2019 | 06:22 PM
BruceJeremy's Avatar
BruceJeremy
Hi folks. My fuel tank needs replacing but I'm worried a new tank will not have the necessary strap supports due to the deteriorated box. Does the fuel tank tie into the underside of truck bed at all? Thanks.
Old Nov 26, 2019 | 10:44 PM
geo6x's Avatar
geo6x
No. Tank is held in with two straps. One end of each strap bolts into frame cross members, other end has a tab that fits into a bracket on the left side frame rail. Check your mounting straps for corrosion before re-using them. Do yourself a favor and don't start the job until the tank is near empty. I did mine with about 22 gal of sloshing fuel inside....very hard to maneuver. Re-mounting an empty tank is a one-man job and quite easy. There are about 7 hose/electrical connections....some are difficult access, be careful not to break tabs on the electrical connectors. Lower the tank slightly onto stands or blocks to aid access to the most difficult ones. Good luck with your repair!
Old Nov 27, 2019 | 06:43 PM
steve(ill)'s Avatar
steve(ill)
you can buy new straps off e-bay... You can also make straps from 1/8" x 1" x 3 ft steel bar from the hardware store.
Old Nov 28, 2019 | 07:34 AM
BruceJeremy
Ok, thanks a million for the tips! Super appreciate it.
1975 f250 4x4
Aug 16, 2018 10:39 PM
Paul Van Benschoten
1997 - 2003 F150
Jun 11, 2015 06:44 AM
410 Highboy
Dec 23, 2013 06:18 PM
mrlightrail
Jul 9, 2008 02:42 AM
tjbeggs
Dec 29, 2006 05:08 PM
