Sponsored by: Auxito
Coil packs
Old Nov 26, 2019 | 01:49 PM
Murkin MurDock's Avatar
Murkin MurDock
Coil packs
So I’m putting my coil pack back in after new intake manifold and I read somewhere that the coils have to go back in the same spot as they were before I took them out.. is there any truth to that, or can I just pick a hole and put them in??
also do the coils packs have to be torqued down?
thanks casey
2001 Ford F-150 xlt 5.4L
Old Nov 26, 2019 | 05:32 PM
Bluegrass 7's Avatar
Bluegrass 7
Coils do not have to be put back in the same cylinders.
Torque the holding bolts just enough so they don't come loose.
Old Nov 26, 2019 | 10:42 PM
z31freakify's Avatar
z31freakify
IMO you should replace the COP boost and springs if you haven't, and re-torque the spark plugs to 20ft/lbs.
Old Nov 29, 2019 | 02:41 PM
Clutch5sp's Avatar
Clutch5sp
Don't skimpout not applying dielectric grease where boot & plug mate. Always blow out the holes with comp air before removing coils & then the plugs. A lot of carap gets all up in there.
Old Nov 29, 2019 | 05:37 PM
Murkin MurDock
I did buy new boots and springs for my cop... I also bought new pigtails that plug into the top of cop off amazon for $12.99 if anyone cares lol. Because 4 outta 8 were broke, but my question is when I instal new ones it’s as easy as line new one up with old one and make sure I solder the right one together. From what I can tell the cop wires don’t cross to the pigtail at all. Just straight on straight.
thanks Kc.
2001 Ford F-150 xlt 5.4L v2.....200k wanna see 300K
Old Nov 29, 2019 | 09:00 PM
DBGrif91's Avatar
DBGrif91
The main reason is for misfire diagnosis. If you were seeing misfires before replacing the plugs, putting the coils back in their original positions would allow you to determine if the coil is at fault.
Typically the coils would be swapped between cylinders to determine if their faulty, but if the plugs are worn enough, that’s not always conclusive.
Also if it’s just the plastic connector that’s broken, you can remove the terminals from them and swap the new connector in without splicing the wiring.
Old Nov 29, 2019 | 10:01 PM
Murkin MurDock
normally you are correct, but with the ones I bought there made a little different where I can’t just slide the old plastic off and put a new one on. A little more work but doesn’t bother me I have a nice Milwaukee soldering iron.
Old clip
New clip and they snap in and stay connected
now it’s time to put my new injectors in. Is it easier to take the fuel rail off to do them? I already have my throttle body taken off.. or should I just take the 4 bolts out and swap them out quick?
thanks for all the help with everything..
Old Nov 29, 2019 | 10:49 PM
Bluegrass 7
I see ACCEL coils in your photos.
A no-no from experience a long time ago that cost a lot of money in related damage..
Your going to end up replacing them.
Look at Mode 6, test 53 for the cylinder/s with the misfires.
This is the hint those coils have to go.
Chinese mfger, not good.
Good luck.
Old Nov 29, 2019 | 11:17 PM
Murkin MurDock
Good luck.
those coils have been in for 4-5 years now.. I take it they cause misfire? I haven’t had a misfire until last week because the intake manifold didn’t get torqued down right which was jack fault lol.. and taking it apart again I noticed broken fuel injector, broken coil pigtails, and I small rip in rubber boot and I bought 8 new ones and I used dielectric grease when putting new boot on.
And I have this scanner coming Saturday. I never herd of mode 6 before until a couple days ago but it seems like it help a lot.
Old Nov 30, 2019 | 01:10 AM
DBGrif91's Avatar
DBGrif91
I would pull the rail and replace the regulator while you’re at it. With the rail off and the regulator out, you can blow some compressed air through the rail to make sure it’s clean.
Once the o-rings are on the injectors, a little dielectric grease helps them slide easily back into the rail and the manifold. Twist each one back and forth to help them seat and torque the rail bolts to 89 in-lbs.
Old Dec 1, 2019 | 03:39 PM
96f150's Avatar
96f150
You mentioned your intake wsnt torqued down correctly........Chances are good that you got coolant into the intake ports........How long has this engine run since you replaced the intake? sometimes this takes a while of runnning to burn off any coolnat that got down in the cylinders. And that would also cause a misfire
steeltown08
Mar 27, 2017 06:08 PM
meade01
2004 - 2008 F150
Feb 6, 2015 11:56 AM
miko6810
May 6, 2014 09:18 PM
njf207
16
Jan 13, 2009 09:25 AM
tofer76
Electrical Systems/Wiring
Oct 16, 2004 11:58 PM
