Electronic locking axle vs non-limited slip
Old Dec 1, 2019 | 02:29 PM
  #76
Mikelikesit's Avatar
Mikelikesit
I havnt used my E locker yet. I was wondering. When it disengages at 20...does the button return to original position? or does it re engage as you return below 20? Or do you need to engage it again if still needed?
Old Dec 1, 2019 | 03:34 PM
  #77
TeddyD's Avatar
TeddyD
It will re-engage when you get below 20 unless you push the switch in. Switch stays pulled out till you manually push it back in again.
Old Dec 1, 2019 | 11:43 PM
  #78
Adam R's Avatar
Adam R
Originally Posted by 00t444e
I don't have any of those problems, it unlocks when cornering just like its supposed to. Yes the rear end can slide out if you lose traction but that will also happen with a limited slip, and you are less likely to lose traction with a limited slip or locker than you are an open differential. The Detroit locker works great for daily driving, there is no way I would trade it for a selectable locker.
I've been in the wheeling community for 25+ years. I think you are the first to say that a Detroit "works great for daily driving." Your Detroit will only unlock if you lift your foot off the gas pedal. Otherwise, it is locked when under power. You must be coasting through the corners, which is what you learn to do when you drive with one of these lockers. Each locker has a set of compromises, but my preference is open/open with the ability to manually engage either electronically or via air and I'll take electronic over air after owning both for many years.
Adam
Old Dec 2, 2019 | 12:16 AM
  #79
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Adam
I had a Detroit Locker in my 74 F100 for 100k+ miles and it was perfectly fine in rain, snow and daily driving. Actually it made that 2wd truck a beast in snow storms compared to an open diff. The only time it acted funky was in tight maneuvers backing up.
I’ve never understood why people were scared of them on the street... must be a Jeep thing
Old Dec 2, 2019 | 01:37 AM
  #80
ForCal's Avatar
ForCal
Originally Posted by Bullitt390
I had a Detroit Locker in my 74 F100 for 100k+ miles and it was perfectly fine in rain, snow and daily driving. Actually it made that 2wd truck a beast in snow storms compared to an open locker. The only time it acted funky was in tight maneuvers backing up.
Toyota, not Jeep, but the short wheelbase rigs can be more easily upset by the autolocker. Im not sure what an open locker is, but I find it odd that someone would prefer an auto locker, with all its quirks, over a selectable locker for a street driven truck. The Detroit locker is good for what it is, it's used by many in off-road toys, but having full control with the push of a button just makes more sense, especially for a mostly street driven, daily driver. Sure you can get used to an auto locker, maybe the noise and extra tire wear doesn't bother you, but all that can be avoided with a selectable locker. Just push a button for the 1% of the time a locker is needed.
Old Dec 2, 2019 | 03:24 AM
  #81
Willy Sunshine's Avatar
Willy Sunshine
My truck does have the limited slip now called traction control. It also has the electric locking rear axle. So as you say that with 4wd is the best of multiple options. I have no intention of doing intentional mud bogging, but for the backroads and remote destinations, everything helps. That is why I will be adding a winch too. This truck is a very impressive beast.
Old Dec 2, 2019 | 05:48 AM
  #82
00t444e's Avatar
00t444e
Adam
There are several even on this forum that daily drive Detroit lockers and have had the same results I have. An auto locker will unlock any time the outside wheel tries to turn faster than the inside wheel when going around a turn, doesn't matter if your on the gas or not. I also have auto lockers in my Jeep and hardly notice them at all on the street, other than the fact that I have much better traction than I did with an open differential. I don't like selectable rear lockers because they are either open or fully locked like a spool, I don't want either of those options when driving on the street.
Old Dec 2, 2019 | 06:08 AM
  #83
00t444e's Avatar
00t444e
I agree, that's been my experience as well and like I said previously they even do fine in my Jeep for daily driving. Maybe some people are just bad at driving in the rain and snow so a locker makes it worse for them. If you drive sensibly, an auto locker is much better than an open differential in slick conditions.
Old Dec 2, 2019 | 08:13 AM
  #84
Bullitt390's Avatar
Bullitt390
Maybe. Could also be the original Detroit Locker from 40+ years ago, those were notorious for being loud and obnoxious versus the newer Detroit.
Again, I never had issues and preferred it to an open differential. The Traction Control seems to do well.
Too bad the Super Duty doesn't have the AWD option like the F150... now THAT was awesome
Old Dec 2, 2019 | 08:17 AM
  #85
tony m 6.7's Avatar
tony m 6.7
The one time that you may need the e-locker it's definitely worth it. If you never use it I'm sure it's a great option for resale.
Old Dec 2, 2019 | 08:43 AM
  #86
17 Oaks's Avatar
17 Oaks
X2 and that is WHY I run ARB's...yea takes an air compressor and air lines to the F/R, but in 7 years and almost 100k miles I never had an issue. They do get a bad rap due to air line issues, but that is because people do not know how to install an air line. Guys would bring them into my shop with a pulled air line. No service loop and the air line just flopping in the wind underneath like they never heard of Zip ties...
Also, there is the Jeep 97 in wheelbase vs the 140 ++ Superduty wheelbase. If get serious and technical in the off-road game the ability to lock and unlock becomes very important and that is where Detroit falls short you cannot control it...
Old Dec 2, 2019 | 10:52 AM
  #87
Adam R's Avatar
Adam R
From Detroit's own website, "Operation During straight-line driving, the Detroit Locker captures 100% of available torque and sends it equally to both wheels."
Some of you guys driving Detroits don't understand how they work. If you are under power, the Detroit is engaged and the wheels are locked together. It will unlock when you lift your foot off the gas pedal. Simple as that.
This means that if you are under power in a corner, one of your wheels is being forced to slip and greatly accelerating tire wear. You get around this by lifting off the throttle to let it unlock. If you tires are slightly different sizes due to air pressure differences, they are always fighting one another in a straight line which also leads to greater tire wear. If you can live with their quirks and extra tire wear, more power to you. I've run ARB's, and still own a Detroit and 4 e-lockers in my current fleet of vehicles. A Detroit would be my last choice of a locker in any future vehicle.
Old Dec 2, 2019 | 11:01 AM
  #88
Bullitt390's Avatar
Bullitt390
What you posted disagrees with what you’re saying, as does this video:
Old Dec 2, 2019 | 01:19 PM
  #89
alabamatoy's Avatar
alabamatoy
Wow, got a good laugh outa this post. I have had multiple lockers including Detroit, Detroit EZ Locker (still using, in the front diff), and a Grizzly, and none of them are something I would consider even remotely tolerable on the street for daily driving. I have been active in 4X4 community (clubs, SFWDA, UFWDA etc) for many years, and this is the first time I have ever seen or heard anyone say that a Detroit is fine on the street. In fact, most people prefer a spool on the street over a Detroit - at least you know its not going to unlock partway through a 45MPH turn, which with a softly-sprung 4X4 can nearly cause loss of control. I just recently removed my Grizzly (slightly less obtrusive than the Detroit) and replaced it with a Toyota E-Locker. I can't imagine how a Detroit would be on a Sterling 10.25 (the Ford F250 diff), when it unlocks in a tight turn, I imagine it would sound like a 7.62 round going off.
Old Dec 2, 2019 | 01:23 PM
  #90
alabamatoy's Avatar
alabamatoy
I agree, but only for a street vehicle. If its purely offroad, the Detroit is very good solution, or perhaps farm use where on-road is minimal. But for a mostly street vehicle, definitely last choice.
