Correct Mini Starter wiring
Old Nov 24, 2019 | 12:21 PM
NewClimber's Avatar
NewClimber
Can someone help to confirm the correct min- starter wiring.
Both methods would seem to work, but with picture 2, why the need for a big solenoid?
thx
Picture 1: you jumper the small wire at the S terminal to the 4ga power wire coming from the 4post starter solenoid.
Picture 2, power is always to the starter, and use the other side of the 4 post starter solenoid to the small wire terminal of the starter.
Old Nov 24, 2019 | 12:35 PM
Mixer man's Avatar
Mixer man
Picture #2 eliminates high current switching in the relay, reducing the possibility of welding the contacts and starter over-running, and prolonging relay life, but what could go wrong? You could probably use a starter relay from a lawn tractor (which actually cost more).
Where is there a 4 gauge wire?
PS: The solenoid is on the starter.
Afterthought: In pic #2 why do you even need a relay? Vehicles were wired that way for decades. Just use the solenoid.
ford390gashog's Avatar
ford390gashog
Picture number two is correct. That is also how ford did it in later years. You need the first relay to trigger the second relay due to amperage requirements of the starter mounted relay.
Old Nov 24, 2019 | 12:47 PM
NewClimber's Avatar
NewClimber
Will go with picture 2. Thx for confirming.
Would it be advised to add a fuse on the smaller wire to the starter S terminal?
Old Nov 24, 2019 | 12:51 PM
NewClimber's Avatar
NewClimber
Mixerman....I dont have a relay in the wiring for picture #2, just the ford solenoid?
I am thinking there would be effectively two solenoids, one the ford solenoid, the other in the starter to engage the starter.
Old Nov 24, 2019 | 01:13 PM
Mixer man's Avatar
Mixer man
What you are calling a Ford solenoid is actually a relay. The solenoid on the starter already incorporates a high current relay. The Ford relay is actually redundant as the starter solenoid primary circuit is very low current and can be fed directly from the ignition/starter switch, and the coil boost circuit can be parallel wired to the primary solenoid circuit as well because it's only used during starter operation. That said, there is nothing wrong with having a second relay.
Old Nov 24, 2019 | 01:20 PM
Mixer man's Avatar
Mixer man
This isn't usually done, but could be. If you are concerned then measure the current inrush to select the proper fuse size.
Old Nov 25, 2019 | 10:46 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I had the same dilemma when going to a mini-starter. I went with #1, because I didn't really care for having the big cable to the starter "hot" all the time (runs near headers). Also as a practical matter, I didn't like having two big lugs on one terminal of the original solenoid. That same terminal would also be used for supplying power to the horn relay and the whole rest of the truck, so there would be quite a stack of stuff on one post.
Old Nov 25, 2019 | 11:24 AM
Mixer man's Avatar
Mixer man
Why have two relays??
This is all you really need. Remember that the original Ford starters did not have solenoids so a relay was needed.
Old Nov 25, 2019 | 12:21 PM
ALBUQ F-1's Avatar
ALBUQ F-1
#1 looks original, don't want to lose points when going for a Dearborn award
1992FordF150Custom
13
Nov 6, 2013 06:54 PM
19fifty4
22
Nov 5, 2013 07:58 AM
leforrest
1997 - 2003 F150
Jan 24, 2013 07:34 PM
websthes
Electrical Systems/Wiring
Sep 14, 2007 06:56 PM
buttnuttn8
Oct 22, 2002 07:19 AM
