Offroad & 4x4
4x4 clunk
Old Nov 24, 2019 | 10:00 AM
95 f150.'s Avatar
95 f150.
4x4 clunk
Please forgive me if there is already a thread on this topic but I can't find one. I have a 95 f150 4x4 with auto locking hubs. The problem im having is when I kick it in 4 wheel drive, I go forward and it jumps the front end up with a loud clunk and what sounds like something dropping or snapping, same thing happens when switching directions (forward to reverse). It sounds decent when driving forward after the clunk but whenever I turn a smaller clunk occurs. Is this common or should I be concerned about something? I am new to 4 wheel drive so please help!
Thank you
Old Nov 25, 2019 | 12:54 AM
85e150's Avatar
85e150
Are you on a hard surface when this occurs?
4x4 is for soft or slippery surfaces only. Running in 4x4 on pavement will produce the clunking you describe.
Don't run it on wet pavement either.
Ratios can be slightly different front to rear and wheel speed is always different when turning. In 4x4 the axles are locked together and the driveline "winds up". Clunking, chirping and broken parts follow.
Old Nov 25, 2019 | 06:24 AM
tjc transport's Avatar
tjc transport
i ain't rite
it could also be a bad universal.
Old Nov 25, 2019 | 05:46 PM
95 f150.'s Avatar
95 f150.
This happens on wet, slippery mud.
Old Nov 25, 2019 | 05:48 PM
95 f150.'s Avatar
95 f150.
Brand new U joints, so hopefully not lol.
Old Nov 25, 2019 | 08:12 PM
85e150's Avatar
85e150
Sounds like it could be related to this issue. Did you ever get this sorted out?
https://www.ford-trucks.com/forums/1...cky-wheel.html
Old Nov 26, 2019 | 04:00 AM
tjc transport
i ain't rite
axles too, or just the front driveshaft?
Old Nov 26, 2019 | 09:50 PM
95 f150.'s Avatar
95 f150.
Yes I belive I have gotten it figured out. I bought the truck in July and it came with a lift and I found the lift kit brackets werent torqued down correctly. I havent tried the 4x4 yet but im hoping torquing them down will fix both the problems!
Old Nov 26, 2019 | 09:52 PM
95 f150.'s Avatar
95 f150.
The axles as well
Old Nov 27, 2019 | 05:10 AM
tjc transport
i ain't rite
loose suspension parts will definitely do it!!!
hopefully the loose bolts did not wallow out any holes.
Old Nov 27, 2019 | 09:20 AM
95 f150.'s Avatar
95 f150.
Thank you for the help!
VA13FX4
Dec 4, 2018 04:47 PM
CR3999!
Oct 18, 2015 05:17 PM
ItsMREMT
Aug 23, 2011 08:52 PM
is300wrx
Offroad & 4x4
21
Dec 6, 2006 05:33 PM
4xfordbronc
1978 - 1996 Big Bronco
Nov 12, 2003 01:32 AM
