Clunk + “Check 4X4”
Old Nov 29, 2018 | 05:10 PM
VA13FX4's Avatar
VA13FX4
Clunk + “Check 4X4”
Yesterday I used four wheel drive to get down an unplowed road and then switched back to two wheel once I got to highway. A few minutes later I was about to pull onto another unplowed road and as I was slowing down at around 20 miles an hour I flipped the dial to four high and there was a loud clunk coming from somewhere in the front end of the truck followed by a message that popped up saying check four wheel drive. I tried a couple more times and the same thing happened each time. I called to make an appointment for service and they will look at it on Tuesday. However, this morning I was losing traction on a snowy driveway and flipped the dial to 4 high and It shifted with no issue. Anyone ever experienced this before? My concern is they won’t be able to diagnose or replicate anything at the dealership and it will do the same thing to me sometime when I really need the front end engaged.
Old Nov 29, 2018 | 06:56 PM
cficare's Avatar
cficare
Originally Posted by VA13FX4
... followed by a message that popped up saying check four wheel drive.
Most likely that message means your truck recorded the incident so there should be no doubt that it occurred. What cause the clunk? I don't know.
Old Nov 30, 2018 | 08:38 PM
VA13FX4's Avatar
VA13FX4
I didn’t think of that. I hope so.
Old Nov 30, 2018 | 09:00 PM
eberlestock's Avatar
eberlestock
On my 17 duty, after I engage 4x4 the truck needs to move a few hundred yards before I get on the gas or it makes a big clunk. The vacuum system takes a while to engage the hubs. If you are under power before they engage, they clunk into engagement. I have never seen a check 4 wheel message though. I didn't even know the truck had such a message! Let us know what the dealer says.
Old Nov 30, 2018 | 10:12 PM
TheGalacticSkull's Avatar
TheGalacticSkull
Same or similar type of topic on the 2015+ F150 Thread. Perhaps a parallel situation?
https://www.ford-trucks.com/forums/1...front-end.html
Old Nov 30, 2018 | 10:36 PM
VA13FX4's Avatar
VA13FX4
I’ve used 4wd dozens of times before and it’s never made a sound. It’s always been almost instantaneous engagement too, 5 seconds tops. If I’m at a stop it normally engages without moving more than a few feet. I’ll let ya know what the dealership says. I got out and locked in the hubs and the front end pulled me up the icy hill, so I’m assuming it’s a vacuum issue. It’s also the first time I’ve used 4wd in temps under 30.
Old Nov 30, 2018 | 11:54 PM
HRTKD's Avatar
HRTKD
This is pretty much my experience. I had to pull my 11K toy hauler in the snowy/slick conditions. 4Hi and 4Lo when off the pavement or I simply wasn't going anywhere. Forwards and reverse. I had zero problems with shifting the transfer case.
Old Dec 1, 2018 | 12:28 AM
ford390gashog's Avatar
ford390gashog
The vacuum hubs only release when not under power, if you stayed on the throttle I bet one of the hubs stayed engaged. The clunk was from the other hub engaging and because one side was still spinning the axle shaft. The spider gears were turning the carrier and the driveshaft was probably under decel condition which caused the shift motor to trip the over amperage setting in the TCCM and trigger the dash warning. The message on the screen was from a incomplete 4x4 shift timeout that comes from the shift motor. These are not stored faults and are not readable even in mode 6 data.
Old Dec 1, 2018 | 05:58 AM
VA13FX4's Avatar
VA13FX4
I was decelerating the first time it happened. Had been going about 35 and flipped the switch from 2wd to 4Hi at about 20. Then the clunk and message. So I flipped it back to 2wd. Still coasting/slowing at about 5mph I tried again and got the same thing. Then tried from a stop, then with it in park, then after turning the truck off and on. Same result with the clunk and message. A while later I was going 60 on the highway for 20 minutes and then tried again while in park when I got where I was going. Same issue. Then after sitting for 36 hours it worked fine.
Old Dec 4, 2018 | 03:23 PM
VA13FX4's Avatar
VA13FX4
Dealership wasn’t able to replicate the issue but found a broken transfercase motor clutch wire. Hopefully that solves the issue permanently.
Old Dec 4, 2018 | 03:41 PM
cficare's Avatar
cficare
... but found a broken transfercase motor clutch wire.
That's a good start, but raises the next logical question; What caused that wire to break? I'd want some root cause analysis to satisfy me.
Old Dec 4, 2018 | 04:04 PM
VA13FX4's Avatar
VA13FX4
I had the same question. The only thing they could come up with was that it must have happened at the factory and it just happened to be an issue the first real snow I drove in. I normally shift into 4WD once a month when I’m on a gravel road just to make sure everything is still functioning and I’ve never had any issues with it, so I’m not sure I buy the coincidence reasoning.
Old Dec 4, 2018 | 04:21 PM
cficare's Avatar
cficare
... and it just happened to be an issue the first real snow I drove in. I normally shift into 4WD once a month when I’m on a gravel road just to make sure everything is still functioning and I’ve never had any issues with it, so I’m not sure I buy the coincidence reasoning.
To me, that makes a little bit of sense. It's a common thing for snow-pack to develop behind the tires and in the fenderwells. If the tires had been throwing up snow/ice/water to collect where that wire was, and it froze in place, a good bump may have broken the ice chunk loose ... and taken a wire with it. So the next RCA question becomes, "Why was that wire (or harness) so vulnerable to such an occurence?" Seems like that would've happened to many SD owners.
Old Dec 4, 2018 | 04:47 PM
VA13FX4's Avatar
VA13FX4
Snow pack shouldn’t have been an issue as I had just pulled out of the garage and drove maybe 10 minutes with no prior driving in snow.
billbot
Aug 17, 2010 02:10 AM
BostonX73
Mar 16, 2010 11:36 PM
BlackFX4Screw
2004 - 2008 F150
18
Jun 5, 2008 04:36 PM
Theoneandonly
1997 - 2003 F150
Jan 30, 2008 06:09 AM
crashtester
Feb 3, 2007 09:04 AM
