Bump Stop Extender?
Old Nov 24, 2019 | 08:52 AM
morgaj1's Avatar
morgaj1
Bump Stop Extender?
I installed the ReadyLift 2.5" leveling kit and didn't like the nose-high look. So, I replaced the lift blocks with Rough Country 1.5" blocks and left the rest of the ReadyLift kit in place (bump stop extension, track bar relocation, etc). I noticed that I don't have much clearance between the front axle and the bump stops with the extensions in place. Is it going to hurt anything if I remove the extensions and leave the factory bump stops in place? Will that allow too much axle articulation?
Old Nov 24, 2019 | 10:12 AM
ForCal's Avatar
ForCal
Does that kit use shock extensions? If it does, you might run the risk of bottoming out the shock without the bump stop extension. What I'm getting at is, if you remove the bump stop extension, also remove the shock extension, if it has them. As far as over extension goes, there are shocks made for +1",2" etc., although it shouldn't be an issue unless you are really drooping out or flexing hard offroad.
That's one of the things I like about the 2" BDS kit (dont currently have it), no bump stop or shock extensions, just the appropriate length shocks, allowing for more up travel before hitting the stops
Old Nov 24, 2019 | 11:18 AM
morgaj1's Avatar
morgaj1
Great feedback, thank you!
Old Nov 25, 2019 | 10:34 AM
speakerfritz's Avatar
speakerfritz
there are aftermarket bump stops like sumo springs that are larger and even include spacers.
17PlatinumSFL
Jul 18, 2020 06:02 PM
2civicrr
6.7L Power Stroke Diesel
Mar 29, 2017 01:56 PM
navistarnut
Feb 29, 2016 04:02 PM
saltamontes
Mar 3, 2009 03:43 PM
BigBlockGuru
Jul 29, 2004 09:40 PM
