1978 - 1996 Big Bronco
leaking transfer case
Old Oct 10, 2003 | 03:28 PM
Black Ford XLT's Avatar
Black Ford XLT
Seems my tranny case is leaking, at the seams .Over filling my transfer case with fluid ,any one do a front main transfer case seal change . How hard is this (1356 electric shift trans)is there any seals or gaskets i need to change while doing this> thanks TR the transmission was rebuilt by ford 14000 miles ago do u think they would of put a new transfer case seal in it?
Old May 24, 2012 | 06:00 PM
Beast01's Avatar
Beast01
1356 BW TC Input Seal?
Have the same problem and have searched the internet and various sites. No detailed write up that I have found thus far after a week or so. Is this not a popular subject or is it really that easy to handle? My question is serious. I am NOT a mechanic. I like to DIY but, I like to do it by lessons learned by guys here. It took me a day( all day) literally to do a rear axle seal/bearing and replace the spring/locker assembly in the 8.8 so, this is a bit intimidating for ME to say the least. Any help out there? Gents, it would be greatly appreciated.
Thanks,
JT
Old May 24, 2012 | 07:58 PM
masseysbronco's Avatar
masseysbronco
No, it's a pretty easy project, but you should probably check a few other things while your in there. There are several good writeups over on fullsizebronco.com that you should check out. Permagasket black is what I used on mine when I rebuilt it. I would replace the pads on the forks while I was in there and do the pump arm modification before it spins free and destroys the case. It's a project that can be done in 4 hours taking your time if you familarize yourself with the case before taking it out.
BigSexy78
Jun 15, 2017 09:05 AM
tcesni
Escape & Escape Hybrid
May 25, 2016 07:07 AM
Byoung Oh
Mar 23, 2016 07:20 AM
Marvo
Oct 27, 2013 05:01 PM
wsconner
Nov 1, 2012 03:34 AM
