Front Transfer Case Seal Replacement
Old Oct 27, 2012 | 05:21 AM
wsconner's Avatar
wsconner
Noticed a small bit of leaking trans fluid on garage floor and my mechanic says I need a front transfer case seal. Anyone know what a dealer would might charge based on standard ford service for this repair. Advisable to do the rear seal at the same time? Many thanks...
Old Oct 28, 2012 | 04:56 PM
68bluebeast's Avatar
68bluebeast
Is it the input shaft seal?
Old Oct 30, 2012 | 01:29 PM
D-Cell_Mekanick's Avatar
D-Cell_Mekanick
All depends on what seal is the one that's leaking. We had our front output shaft seal replaced under the extended warranty we had. Normally I would have done the work myself, and actually I started to. But soon found out the yoke was part of the output shaft so the case had to be split in order to change the seal. If I recall correctly it was over a $1200 job.
Old Nov 1, 2012 | 03:34 AM
wsconner's Avatar
wsconner
follow up
Thanks for the info everyone. Just for future reference, my mechanic (not a ford dealer) completed the replacement of the front output shaft seal in 5hrs for $400. Parts were about $45. The had to drop the front part of the transmission which was most of the labor. My 05' Expdy has 114K miles.
jumbofordman
Jan 2, 2018 10:42 PM
JGRNAUT_7.3L
15
Dec 21, 2017 08:49 PM
herbiemin
May 28, 2015 10:10 PM
cmlind
Apr 27, 2005 07:31 AM
