Best steering stabilizer ?
Old Nov 21, 2019 | 11:37 AM
Badford's Avatar
Badford
I'm looking at these two. Which one is better? Looks like the Kelderman has better brackets. Also Fox shocks vs Bilstein
https://kelderman.com/shop/2017-ford...ilizer-bracket
2005-19 Ford F-250/350 HD Dual Stabilizer Kit
Old Nov 21, 2019 | 12:15 PM
Shooter73's Avatar
Shooter73
4wd Low
I don't have one yet, but take a look at the Stryker design as well. From a strength point of view, it seems the strongest.
Old Nov 21, 2019 | 07:14 PM
Badford's Avatar
Badford
THe Stryker kit does look strong. The kelderman bolts on the outer brackets vs the clamp on.
Old Nov 22, 2019 | 10:12 AM
Tedorama's Avatar
Tedorama
Go with the KING!
Old Nov 22, 2019 | 10:13 AM
Shooter73's Avatar
Shooter73
4wd Low
Originally Posted by Tedorama
Go with the KING!
How much was it, Tedorama? Obviously, you like it?
Old Nov 22, 2019 | 10:55 AM
Tedorama's Avatar
Tedorama
I went directly through KING Suspension and I believe it was $180, best upgrade for the money in my opinion. I did purchase a longer bolt as I wanted more thread exposed than the one it came with as the photo shows the supplied mounting bolt.
Old Nov 22, 2019 | 11:35 AM
jbjones85's Avatar
jbjones85
Does it just install in the oem location? What tire size are you running.
Go with the KING!
Old Nov 22, 2019 | 11:57 AM
Tedorama's Avatar
Tedorama
Im running 2.5" level spacer, with adj. track bar, sway bar extensions, Icon shocks professional alignment with no caster shims needed
22x10 Rhinos with 37x12.50 Toyos, no rubbing except full lock backing up over dip on front air dam corner, doesn't rub no after 15k miles with this combo
Old Nov 22, 2019 | 12:53 PM
Tedorama's Avatar
Tedorama
yes, easy install in oem location, you will need a pickle fork pry bar available at Harbor Freight(less than $10) to remove oem SS.
Old Nov 22, 2019 | 05:01 PM
ymsmiley's Avatar
ymsmiley
Go with the KING!
Old Nov 22, 2019 | 05:17 PM
MrOneEyedBoh's Avatar
MrOneEyedBoh
Why go with king, besides its more expensive...? I mean wouldnt a Fox 2.0 still be way better? Its just a stabilizer...
Old Nov 22, 2019 | 09:56 PM
SARDiverDan's Avatar
SARDiverDan
Depends on what you need it for and how much you want to spend. For the majority of trucks I have seen with high-end kits, the only time they go "off-road" is if they accidently drive over their grass on the way out of their driveway... Here is a quick comparison of the two major brands.
Fox Vs. King
I would say a fox 2 is more than adequate for a SS for most folks.
Old Nov 23, 2019 | 06:27 AM
17 Oaks's Avatar
17 Oaks
Rancho, 20 years of buying them, selling them, installing them on bone stock to RADICALlY modified rigs, never had a come back, never had an issue, they make 2 for the Superduty, one based upon the RS 5000 series and the other on the RS 7000 series, they also make a dual shock setup. About $68 / $85
Kool factor $0.00
Work Factor Priceless
New Rancho 5415 SS installed, time approx 15 min
Old Nov 23, 2019 | 12:17 PM
SPrew94535's Avatar
SPrew94535
So would installing this help with the stopping of the death wobble? Or as an added prevent to the possible oncoming off the wobble? Thanks.
Old Nov 23, 2019 | 12:25 PM
MrOneEyedBoh
Personally and I think some will agree, the stabilizer is just that.. stabilizing the wobble... There are underlying issues that are causing it, and the steering stabilizer/dampener is doing its job. Stabilizing/dampening.
So all in all, no that wont F I X the problem, but mask it and help it. Until the stabilizer wears out.
