Help with leaking radiator 2001 7.3
Help with leaking radiator.
Drove 6 hours from Philadelphia Pa to Boston Ma.
While in Boston radiator suffered a major leak.
I was forced to leave it at a Ford dealership even though I didn't want to.
It It was a Sunday and nothing else would answer the phone. Had to get to work early the next morning.
Three days 3 days later and quoted $1700 to completely re place the radiator and new coolant.
I I won't be able to get up there for another 2 weeks.
My My question is is this reasonable because it will cost me another $500 to lose A-day's Pay and I can't afford that right now.
I Any suggestions would be much appreciated it is located in Stoneham Ma at Stoneham Ford.
It's to It's too damp cold for me to go up there and spend the day on the street trying to fix her radiator.
I need I need suggestions or help would be much appreciated as I have to let them know not to do the job. Right now I told them to go ahead but they probly won't get to it till Friday.
That's a bad price. I would start looking for a good independent diesel shop and I would put a Mishimoto in there if I am spending money to replace it anyway. It is not that big of deal to replace. Biggest pain in the butt is getting the fan and fan shroud off and back on. I would also replace the upper and lower rad hoses while at it
It's not hard to believe at all. I'm sorry that whoever worked on your vehicle screwed it up, but thats not the goal.
If you are capable of doing the repair yourself, you would have to have a very high wage to choose having someone else doing it for financial reasons instead of doing it yourself.
I pay my technicians $25-35/hr. Thats $33-50/hr loaded cost after benifits.
Building is $4000/mo, about $10/hr /tech
I pay about $1000/mo for shop management/diagnostic subscribtions/scantool software updates.
at least $1000/mo for utilities
$600/mo for uniforms & Cleaning, Rags, carpets, Soap, Gloves, Paper Towels
$500/mo for random shop supplies
$10,000-$20,000/yr for building & Equipment maintenance and repair (closer to $30k this year)
$2000/yr for yard maintenance
$3500/yr Snow Clearing
$50k/yr service Advisor
This list is lacking.... I pay alot more than this.
My Shop rate is $100/hr
Calculators that tell you how much you should charge based upon expenses say we should be charging $180-200/hr
My Shop grosses $700-800k/yr. (avg 10 cars/day, 2000 cars/year)
The shop nets about $50k/yr. If my math is correct that is 14% profit.
Commercial retail goal is 50% profit. Higher for lower cost items.
Just Curious... how much was the last annual on your cessna? I've been flying since I could tie my shoes. Got my private and float rating about 1990, got my A&P in 1998. Worked on Multi Engine Turbine Helicopters until 2015 when I bought my very own auto repair shop. Haven't touched an aircraft since but I kinda miss it.
How much does the book say a radiator replacement on one of our trucks should be? Can't believe for a second that it should be any where near $1700.
Back on topic. Do you know where the radiator was leaking from? The radiators in these trucks have plastic end tanks with a large rubber o-ring gasket that are sealed to the aluminum core. The typical leak is the tank on the drivers side given that's where we tend to put our knee when we work on these power plants. The stock radiator can be rebuilt and/or patched. Given you stated a major leak, I am thinking the seal between the tank and core is probably compromised...but just fwi, if a crack in the plastic you can weld it back up with a soldering iron to get it back home.
Our Excursion developed a leak years ago and I replaced it...along with the one in the F350...with an all aluminum unit. So no more worries about those seals as this is a one piece unit. Not sure what the local parts store charges for the oem replacement, but these all aluminum units can be had off the interweb for about $200 from what I remember. Since you are replacing the radiator you might go ahead and also replace the upper and lower hoses while you're at it. For the upper hose, get the one for the dual alternators as it goes around the serpentine belt instead of through it such that you don't have to remove the hose to change the belt.
