Aftermarket Products
Sponsored by: Worksport
Adding After Market LED Back Up Lights
Old Nov 20, 2019 | 04:15 PM
rabbit hutch's Avatar
rabbit hutch
I'm still new here and might have placed this in the wrong forum. If so, I hope an admin will move it to its proper place. I didn't put it in a forum based on the year model of my F150 because I think it is a question applicable to most all models.
My '90 F150 4.9L straight drive just doesn't produce enough light for safely backing up. I found a pair of reasonably priced and powerful auxillary LED lamps that I plan to mount beneath the rear bumper angled slightly outward (5-10°). I've never done this before and don't want to create a wiring problem. I don't want them switched separately but want them to come on when the stock back up lights are switched on with lights on and placed in reverse. I watched a YouTube that only confused me further because it involved splicing into hot wire feeding the stock back up light, then adding a relay, fuse, and power wire all the way back up front and connected directly to the positive battery terminal and finally a common ground from the relay to the chassis. That seems to me to be a shotgun for a gnat.
Can anyone tell how to do this and why or point me to a wiki, youtube or how-to article? Is a relay really needed? If so, why? Does the sub-circuit to the relay need to be fused? If so, why? Does 12V power really need to be taken from the battery? If so, why? If not, what other sources to power the relay should be considered?
I searched here but didn't find one on the subject.
TIA
Old Jan 11, 2020 | 07:29 AM
Beerleg's Avatar
Beerleg
I did this in the missus mobile (surburban)
First step I did was this
Amazon Amazon
These were a big improvement over stock, but it got to be at the barely usable point and I wanted more
So the next step was this
Amazon Amazon
That got to the wife seal of approval.
Now in my truck, I had led pods under the bumper first, but wanted something cleaner.
So I did this
Flush mount sr-q lights and rear power port
Now to answer your question
Why a relay..
The backup light circuit is meant for small drawing bulbs, not a larger current draw. So the relay uses a small current to act as a trigger to open the contacts to a power supply that can handle the load.
Old Jan 23, 2020 | 05:47 AM
Bugzilla46310's Avatar
Bugzilla46310
I added the brightest led bulbs to the original backup lights. This helped. Then I added rock climbing lights to the back and side. Am happy with the results. Also added the rock climbers to the front side and tied those to the driving lights for more light on the side.
Old Jan 23, 2020 | 12:53 PM
rabbit hutch
Great job!!!!
Thanks for the post!
tbenks
Electrical Systems/Wiring
Jan 31, 2020 05:29 PM
rebelyell618
Jul 23, 2009 08:07 PM
Bernie Lomax
Nov 25, 2008 06:54 PM
wreedZ71
2004 - 2008 F150
Oct 27, 2008 07:22 PM
rikosintie
Jul 24, 2007 12:11 AM
