Windshield Wiper Issues
Old Nov 20, 2019 | 09:35 AM
jimjokjv's Avatar
jimjokjv
I searched but found nothing conclusive on this.
My intermittent wipers stopped working. The normal ON and FAST run the wipers fine but they won't park properly when switched off.
The intermittent setting results in the wiper starting up the glass but stopping half way.
This isn't due to a leaking windshield and it started when driving in a very light drizzle. I turned them on and off just to clear the windshield but a little later when attempting the same thing they went half way and quit.
Old Nov 20, 2019 | 10:42 AM
Colorado350's Avatar
Colorado350
Jim, I’m guessing the multifunction switch is dying had the same problem with GF’s Commander new switch solved it.
Old Nov 21, 2019 | 05:07 AM
FordTruckNoob's Avatar
FordTruckNoob
I concur with Colorado350. Mine had the same symptoms. Replaced it with this:
Turn Signal Switch compatible with Ford F-Series Pickup 97-00
Amazon Amazon
Old Nov 21, 2019 | 06:38 AM
Colorado350
Turn Signal Switch compatible with Ford F-Series Pickup 97-00 https://www.amazon.com/dp/B009DJT34S..._Z-M1DbG7Q3CPR
‘Leonard, how long have you been running that switch? Any issues with it being NON OEM? Thanks
Old Nov 21, 2019 | 06:41 AM
FordTruckNoob
I have had it since April 2017. So far so good. OEM from the dealer was stupid expensive.
Old Nov 21, 2019 | 06:45 AM
Colorado350
Thanks, MT turn signals don’t wanna stay on unless the wheels are straight and for that price it’s a no brainer.
Old Nov 21, 2019 | 06:58 AM
FordTruckNoob
That's actually because of the cams on the steering column that pop the switch off when the wheel comes back to straight. My turn signals won't stay on unless the wheel is straight or turned way the heck over also. It still does it even with the replacement switch.
Old Nov 21, 2019 | 07:56 AM
Colorado350
OH, ok well thanks for that...
Old Nov 21, 2019 | 08:16 AM
jimjokjv's Avatar
jimjokjv
Thanks for the link.
Captbs32
1978 - 1996 Big Bronco
Jan 12, 2012 10:51 PM
ZukBox II
Oct 11, 2010 03:01 AM
stangman516
1997 - 2003 F150
Dec 5, 2009 01:46 AM
roadtrash43
May 7, 2009 07:23 AM
AManAndHisTruck
Electrical Systems/Wiring
Dec 3, 2004 11:27 AM
