Tailgate mounting hardware question
Old Nov 19, 2019 | 12:18 PM
crisman's Avatar
crisman
Hi Bullnose fans,
Yesterday, I found and buy a tailgate trim in a decent shape (missing the "D" letter).
Well I want to mount in my tailgate but have two plastic reteiners broken, Do you know the name of that plastic pices and a place where can I buy a pair.
Regards
Old Nov 19, 2019 | 05:02 PM
Franklin2's Avatar
Franklin2
You can see those plastic pins where welded (melted) by a machine into the plastic emblem. No way are you going to find those. When I am in that situation I always use a blob of silicone caulk in the spot where the pin is missing. Let it dry and you should be good to go.
If you are afraid of that, I would find some round plastic rod, possibly cut up a plastic coat hanger if it's close, and then epoxy that onto the back of the emblem and see how that holds up. The silicone will work just as well. If you really want it to stick, use that caulk that's called "Lexel". That is pretty sticky stuff when it dries.
Old Nov 20, 2019 | 07:29 AM
crisman's Avatar
crisman
Thanks Franklin, great answer.
In the next few days I will decide if I put it that way or I only use a little glue as you say.
But whatever I do, I post it so that it remains as information.
Regards.
Old Nov 20, 2019 | 08:54 AM
1986F150six's Avatar
1986F150six
These are on eBay, but look to be different than yours.
https://www.ebay.com/itm/Ford-Tailga...YAAOSwk2JcnAb8
Old Nov 20, 2019 | 10:07 AM
crisman's Avatar
crisman
Thanks for the information, but they look different and taller than mine (in the screw parts), and don't shipps to México.
Regards.
P.S. I was thinking of going with a friend who has a lathe and see if he can help me make the pieces
Old Nov 21, 2019 | 07:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1980/84 tailgate finish panel is different than 1985/86, but uses the same clips to mount it to the tailgate.
So, I wonder what year tailgate finish panel the OP bought?
1987/91 F150/350 tailgate finish panel & the clips are different.
1992/96 is different again.
68murc
17
Apr 25, 2019 02:22 PM
Don52M3
Apr 21, 2019 02:34 PM
frank5079
13
Nov 3, 2015 06:24 PM
MHDtr33
Apr 12, 2013 08:10 PM
tjsulli790
Paint & Bodywork
Jun 2, 2007 09:35 AM
