Vibrating under hood
Old Nov 17, 2019 | 03:36 PM
truckermark's Avatar
truckermark
This is what vibrating. As you can see its got a nipple with no line on it. Its on the pass side
Hi. I have a e99 7.3l auto.
I have something vibrating under the hood anytime key is in on pisition. Its pretty loud. Not sure what this is. Any help is appreciated
Old Nov 17, 2019 | 03:40 PM
AllaboutMPG's Avatar
AllaboutMPG
That's your vacuum pump. If it's running all the time you probably have a leak. Is yours 4wd and do your hubs still work?
Old Nov 17, 2019 | 04:00 PM
truckermark
Yes to 4wd. And i have manual leaver in cab and manual lockers. All work fine. Lockers are a luttle hard to turn though. What does this vaccum control?
Old Nov 17, 2019 | 09:09 PM
Brian Hanks's Avatar
Brian Hanks
If you have manual locking hubs then your vacuum lines that normally auto lock your hubs are disconnected. Make sure those lines are plugged. Mine had similar issues and previous owner had cut one side and left it hanging and on the other side was just missing. I didn’t know what was going on and one side was locked for several thousand miles before I figured out while on a lift spinning the tire to isolate a noise what was going on and switched to manual hubs and capped off lines. It caused the auto hub that was locked to wear out is the sound I was chasing at the time. You should have a nipple on your hub that you cap off and then the line runs into a bracket up near the wheel well. However yours may have been completely removed back at the pump.
Old Nov 17, 2019 | 09:57 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
HVAC mode control (floor/vents/defrost)
If it runs all the time you have a vacuum leak in the system somewhere.
Old Nov 17, 2019 | 10:14 PM
truckermark
I will crwal around it tomorow. Thanks for the info.
ESV
May 17, 2019 05:34 PM
Good_ol_boy
Jun 25, 2015 01:09 PM
raidscsi
Aug 25, 2014 12:17 PM
rjfetz1
Mar 6, 2009 02:23 PM
RShaips
Dec 28, 2005 08:53 PM
