Sponsored by: Real Truck
Which front wheel bearing?
Old Nov 17, 2019 | 02:43 PM
artfuldodger's Avatar
artfuldodger
Getting noise ,a whine, and trying to establish which side needs replacing. Have put it up on jacks and rolled the wheels but no noise heard. Have driven it down the road steering from side to side but no difference. Have put it in neutral to remove the driveline , noise continues, and whines down as speed decreases. Short of changing both sides, any suggestions?
Old Nov 17, 2019 | 08:22 PM
Colorado350's Avatar
Colorado350
Year, engine and 2WD or 4WD? Sometimes you just have to wait until it gets bad enough it’s obvious...
Old Nov 17, 2019 | 08:36 PM
Tedster9's Avatar
Tedster9
As a practical matter the other bearing can't be far behind. Just knock both wheels out at the same time, go over the brakes, etc.
Old Nov 17, 2019 | 08:44 PM
crusty old shellback's Avatar
Are you sure it's the front bearings and not something from the rear axle?
Turning right and left, if it's the front bearings, usually will change sounds when turning one way and not the other.
Old Nov 18, 2019 | 07:46 AM
gpeade's Avatar
gpeade
As was mentioned earlier, you may have to drive it a little longer for enough wear to be able to find it. I would suggest jack the tire off the ground, grab the top or the tire with both hands and pull - push it away from and towards the truck. If you have any play then you found your culprit. At least that's how I found mine.
Old Nov 18, 2019 | 09:32 PM
Thejudge's Avatar
Thejudge
Check your brakes.
I thought mine was a wheel bearing. Pulled tire off. Started inspection. Slide pin was stuck and inside pad was worn to almost nothing .
Replaced. All's good. It had the classic bearing symptoms minus the play.
rzaenglein
2004 - 2008 F150
Oct 14, 2016 03:47 PM
72GTS
Jun 15, 2016 09:23 PM
YellowXLT
Escape & Escape Hybrid
Apr 20, 2013 09:39 PM
srauner
Feb 20, 2007 05:09 PM
kcbrown
Jun 15, 2005 08:24 AM
