Speedometer Question
Old Nov 17, 2019 | 09:02 AM
Ruckin69's Avatar
Ruckin69
How do you determine what the right speedometer is for a C4 in a 78 F250?
Old Nov 17, 2019 | 10:03 AM
march's Avatar
march
I'm trying to understand your question since the transmission has nothing to do with it. 78 has the version with the high beam indicator in the top. They come in 80 mph or 100 mph ranges.
Are you asking which speedometer drive gear you need? The number of teeth is determined by your trans, differential ratio and tire size.
Old Nov 17, 2019 | 10:07 AM
Ruckin69's Avatar
Ruckin69
Sorry, I did this post in haste. Yes I'm looking for the speedometer drive gear for a 4.56 32 inch tires C4. Trying to figure out which one I need and where to get it.
Old Nov 17, 2019 | 10:23 AM
march's Avatar
march
You will need to know the rear axle ratio and the number of teeth on the drive gear in the trans and the tire diameter to calculate the number of driven teeth on the speedo gear. I believe your C6 will have 7 drive teeth. But I'm not 100% certain since they came in a variety of configurations.
The formula for calculating the driven gear number of teeth on the speedo cable is as such
# DRIVE TEETH x AXLE RATIO x TIRE REV. PER MI.
_____________________________________________ = # DRIVEN TEETH
1001
To calculate tire revs per mile
20168
_______________________________ = REVIOLUTIONS PER MILE
TIRE DIAMETER (in inches)
So, 20168/32 =630.25 7X4.56X630/1001 = 20
Old Nov 17, 2019 | 11:34 AM
5851a's Avatar
5851a
For a C4 the output shaft on transmission most likely is 7 tooth. Probably not going to get correct reading without a reducer, Ford used them on the cars with the low rear ratio's. Fox Mustang guys would try the aftermarket 23 tooth gears to correct for 3.73/4.10 gears. Ford didn't offer the 23 tooth and they have short life expectancy. If your tires are large enough diameter you might get halfway close with a 21, that just WAG.
Old Nov 17, 2019 | 11:37 AM
Ruckin69's Avatar
Ruckin69
Thank you..
Old Nov 17, 2019 | 02:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Exclamation NO C4/C6 replaceable speedometer DRIVE gears!!!
No 1973/79 F100/350 C4 or C6 has a replaceable speedometer DRIVE gear, because it's made as part of the output shaft!
C6: There are several different DRIVE gears "rolled on the output shaft," one has 6 teeth, the other has 9 teeth // C4 could also have 6 or 9 tooth DRIVE gears "rolled on the output shaft."
The nylon DRIVEN gears are replaceable, come with 16 thru 21 teeth, but the rear axle ratio and the tire size must be known to get the correct gear.
Pic: C6 .. Output Shaft is 7060 .. but there's no basic part number or picture of the DRIVE gear (it's 17285 w/a M/T), because it's made as part of the shaft.
Old Nov 17, 2019 | 03:52 PM
Ruckin69's Avatar
Ruckin69
Thanks ND.
Pepsford
Jun 15, 2018 09:54 AM
hest_c
Jun 27, 2016 10:43 AM
F100Mann
Jul 18, 2013 04:40 AM
palmer77crew
Jan 4, 2012 06:42 AM
muscletruck7379
1978 - 1996 Big Bronco
Nov 27, 2003 12:33 AM
