Sponsored by: Auxito
2001 F150 electrical problem?
Old Nov 16, 2019 | 02:48 PM
Billyg707's Avatar
Billyg707
Unhappy 2001 F150 electrical problem?
Please Help. My truck lost the serpentine belt because the alternator froze up. Both were replaced then the truck would not start and gas gauge did not work. Put a battery charger on it for the night and when I came out two relays were rapidly clicking. I took off the charger and the relay under the hood stopped but the one inside was still going off and the interior light was going on and off (#2 Relay 5A Powertrain Control Module (PCM), Cluster) if you put the clutch pedal to the floor it stops. Pulled out relay and took the battery termanals off hoping it would help but it didn't. I don't have a clue!
Old Nov 16, 2019 | 07:46 PM
Bluegrass 7's Avatar
Bluegrass 7
What motor do you have?
Take a good close look at what the belt could have damaged for wiring.
We have no worthwhile clue until more info is attained except harness damage of some sort.
Good luck..
Old Nov 17, 2019 | 06:45 AM
Billyg707's Avatar
Billyg707
The engine is the V6 4.2 L. WE looked all over and did not see any hanging wires
Old Nov 17, 2019 | 12:46 PM
Bluegrass 7
The belt has to have done damage somewhere in the path the pieces took.
Take a new look at the alternator replacement for pinched/broken wire.
The other effects you describe ae far removed from an alternator or belt replacement unless the issue was caused afterward.
I think you have PATS in a 2001. Take a look at the Theft light and see what it does. Blinks, flashes a code after a couple minutes etc.
Otherwise I have no clue either. It would all be guessing.
Good luck.
Old Nov 27, 2019 | 09:47 PM
Tbuck11's Avatar
Tbuck11
replace the alternator field fuse in the engine bay (I forgot what number it was) and try to jump off your truck. If the truck turns on, awesome. Rev the rpms to around 1500 maybe a little higher to see if it blows the fuse and the battery light comes on. If it does then your voltage regulator is bad or the harness to the alternator is bad. That’s what I did when I had those problems. 2 months of trouble shooting.
frdlvr35
19
Dec 4, 2017 05:35 AM
williameub
15
Dec 14, 2016 10:06 PM
ChambersF150
1997 - 2003 F150
May 23, 2011 08:42 PM
9902ford
Aug 5, 2009 10:25 AM
7scott
Apr 15, 2004 03:41 PM
