2018+ 5.0 Oil Consumption - Ford now says it's software related
This is an interesting development for guys like @smokewagun who had issues across multiple engines. Turns out that it wasn't the engine, but the PCM that was the cause of the oil consumption.
I don’t think it’ll be hard too find an owner with the oil consumption issue to perform said PCM update.
Much better than the first remedy.
Interested in seeing if it really works.
Well, after my replacement mill heading down the same road, it was a wild card for me, until this TSB. Even considering this latest development, I can’t help but wonder if it’s just another band-aid fix for the crappy plasma coated cylinders. Time will prove or dis-prove this TSB. Had I incurred cost to trade to the same optioned and trimmed truck, I’d be sick. But, I really love my new loaded Lariat 3.0L, and being the basic guinea pig for the 3.0L on this board, has really been positive. I loved my last 2018 and the V8, but the oil issue started to get on my nerves. Hopefully they get it right... about time the 4.6L is released to replace it, just prior to the V8 going to the history books.
So some of the PCMs received the proper software but others didn't? This seems strange. If this is the case there should be a recall on all 5.0s for reflashing or reprogramming of the module right? How would they determine which modules received the correct programming and which ones didn't? Why is there more than one program floating around? It's just a weird issue.
It's a case of reverse "blow-by"? Would that be...Don't want to go there I suppose...
I think it just might make sense but "why isn't it a problem with all engines" is a valid point.
I just bought a 2019 SuperCrew w/ 5.0 (with 20K miles on it) and haven't driven it 1000 miles myself.
I checked the oil last Friday before a little trip (500 miles total) but I will check it again tomorrow.
I'm here in the "flatlands" of southern Florida so not much engine braking in my driving.
I'm watching this like all of you.
Steve
"Most of my money I spent on cars, trucks and boats, the rest I just wasted."
Magma Red ain't really "red", I don't care who you are!
Steve
Hope those with the 2019 5.0 don't have as big a problem figuring out the dipstick as I have had. It has read on low hatch mark but high on upper after dealer oil changes. Have topped it off twice with about a quarter of a quart both times and it reads high on both marks. Goes back to those original readings and stays there. Hard to figure. I don't think this truck is using oil and have about decided to not worry about it as long as it registers oil on one side or other of the dipstick.
Why do even dipsticks have to be hard to figure out now?
