The e303 performance cam is Mass Air EFI only!
More than likely due to the 110° lobe separation, which is NOT recommended for stock SD applications.
There are other SD cams that will will work, but will have 114 lobe separation guaranteed to work.
Going down to 112, you probably will have to have a tuner to make it happy.
If you keep your SpeedDensity, you need a computer friendly cam.
Many have success with the xe258hr on SpeedDensity.
So I was looking on summit and found a cam Its a comp extreme energy pt number cl35-512-8 with 114 degree lobe separation it has the same grind number that you gave me so would that be a good cam for my application Stupid EFI I wish I could just put a lunati cam or something without worrying that it'll run like crap.
Also what kind of idle am I going to have as well as more low end power or high end power?
