94 Fuel Pump Issue
Old Nov 13, 2019 | 09:33 AM
my94red4x4's Avatar
my94red4x4
94 Fuel Pump Issue
I have a 94 F150 with a 4.9L engine. My fuel tank is the steel tank in the center of the frame with an in tank fuel pump. These pumps do not like ethanol gas at all, I get about 30,000 miles out of one if I'm lucky. I have been thinking about doing away with the in tank pump(this also gets electrical wires out of my GAS tank) and going to a frame mounted system like the 88-89 trucks have. Has anyone ever done this? Does the frame pump have the same pressure as the in tank pump? Any thoughts? Thank you.
Old Nov 13, 2019 | 10:23 AM
R&RFord's Avatar
R&RFord
The earlier trucks have in tank pumps as well. The earlier system works fine, but there are more parts, so more to go wrong. In tank low pressure pump, in-line fuel reservoir/filter/selector assembly, high pressure pump, then the standard fuel filter. If your problem is ethanol eating pumps then I don't see how having 2 pumps would improve the situation.
I think you would be wiser to consider other explanations for your repeated pump failures.
You would not have a selector/reservoir assembly in a one tank truck.
Old Nov 13, 2019 | 02:54 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Only 30,000 miles from the pump module? Maybe you need to try a different brand or buy different fuel. We have 10% ethanol around here and I haven’t had any problems from the Spectra pumps in 60K miles. You will still have electrical wires in the gas tank for the sending unit.
Old Nov 14, 2019 | 06:31 PM
rla2005's Avatar
rla2005
Yes you would....
courtesy of Steve83
Old Nov 14, 2019 | 07:25 PM
my94red4x4's Avatar
my94red4x4
Originally Posted by rla2005
Yes you would....
courtesy of Steve83
mine doesn’t have anything like this.
Old Nov 14, 2019 | 08:19 PM
R&RFord's Avatar
R&RFord
Thanks RLA. I didn't think about the need for a fuel reserve to keep up with the demand of the high pressure pump even in a one tank system.
To the OP, a 94 will not have a fuel selector/reservoir as there is no need for one with the newer fuel delivery set up.
Old Nov 15, 2019 | 07:28 AM
rla2005's Avatar
rla2005
You are correct. I was responding to the other post regarding downgrading to the older style fuel system with 2 pumps and a fuel reservoir.
TAF
Sep 6, 2019 07:54 PM
bleeds-ford-blue
Oct 26, 2017 10:54 PM
bozzchem22
Jan 21, 2009 01:01 PM
Ford_F-250_1990
Oct 5, 2006 01:28 PM
99f350sd
Jun 15, 2003 10:54 PM
