Sponsored by: Real Truck
7.3 Head Gasket
Old Nov 13, 2019 | 01:40 AM
JR Armbrister's Avatar
JR Armbrister
Angry 7.3 Head Gasket
Just got done replacing a few injectors, got my truck running good. Felt good enough I put about 1500 pounds of square bales on the bed and I had made it about 15 miles and noticed the engine starting to overheat, luckily I was pretty close to my destination and limped it there. Got done unloading the hay and by then the truck had cooled off so I opened coolant cap because it had already sprayed everywhere out of the cap I assume. I started the truck up and coolant immediately began boiling out of cap non-stop. Looked in my oil sump and it looks like a milkshake in there. I am assuming my head is blown but have no clue how I would have blown the head going 60-65 down the highway with hardly any weight on the truck. Truck is blue/white smoking heavily and idles okay.
Old Nov 13, 2019 | 01:44 AM
JR Armbrister
forgot to mention just replaced all injector o-rings and inspected cups, so I do not think it could be the cups.
Old Nov 13, 2019 | 07:10 AM
Djosbun's Avatar
Djosbun
If the head is not perfectly flat (which happens over time due to many heat cycles), it doesn't take much cylinder pressure to force the coolant where you don't want it.
-- Dave
Old Nov 13, 2019 | 08:41 AM
Colorado350's Avatar
Colorado350
Welcome to FTE.
There’s not many head gasket failures on the 7.3L. I think I would investigate a bit more, look at oil cooler etc, BEFORE jumping to the conclusion of a head gasket. When you inspected cups did you pressure test them or just visually look at them?
Old Nov 13, 2019 | 09:56 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
It's either the oil cooler seals, OR the degas cap that failed.
dmelissa1962
Feb 8, 2017 11:45 PM
John McCabe
1983 - 2012 Ranger & B-Series
Nov 17, 2014 02:43 AM
DPDISXR4Ti
31
Jun 19, 2012 07:41 AM
23larry24
13
Aug 1, 2011 09:03 PM
75BigBlock
General Automotive Discussion
Oct 1, 2006 09:37 AM
