Hi a friend of mine asked me to look at his 2001 7.3. Its pushing coolant out the resevoir cap. I am thinking that it needs head gaskets or maybe has a cracked head. Is this common on 7.3's? If anyone has done this, how many hours does it take? Thanks!
had the same problem, with my 99 7.3 and it was the head gasket. took about 3.5 hours to pull and clean the heads. Don't forget to get them checked before reassemble, and go ahead and change the injector cups.
dont condemn the heads yet... several good threads here on injector cup issues and diagnosis....i am leaning to injector cups.... pull vc's take out injectors and pressure test the radiator and look inside each injector hole and look for coolant...
