Sponsored by: Real Truck
Need direction please
Old Nov 12, 2019 | 10:47 PM
Vintage moto's Avatar
Vintage moto
Hey fellas, new to the group and totally Tech illiterate so please bear with me and thank you for your patience in advance
I recently purchased an 09 F250 Super Duty V10 out of Canada through a dealership in North Seattle I got a great deal on the truck and I really love it my intentions upon purchasing it to tow a small rubber track excavator that I have as my 09 Platinum 150 would just get worn out doing that with that said two issues have emerged check engine light within the first 300 miles and a code p0442 small evap leak so upon seeing that I YouTube some videos the truck being out of Canada's Rusty the fuel cap was Rusty everything's Rusty not bad Rusty just rusty so with that I cleaned the cap clean the filler neck cleared the code the code came back I ordered a new cap for my Ford dealer they wanted to sell me an Evap solenoid valve said that's common amongst those trucks I checked around on the web there like 50 60 bucks they wanted a hundred and ten dad said the other thing I've noticed I can't put fuel in that truck in 3 to 5 minutes at all it's 20 minutes at the pump it just keeps clicking off and off no matter where I have the nozzle in the tank the service guy at the dealership said well that's a problem with those selenoid stew so any help on sorting this out because I don't have the money right now to go to the dealer with it nor would I I like to do my own work but this is a new Beast for me thanks in advance Johnny.
Old Nov 13, 2019 | 11:20 AM
the_old_ranger's Avatar
the_old_ranger
Well Johnny, Hello! And they are probably right you have a venting problem.
Old Nov 13, 2019 | 11:49 AM
Mike1's Avatar
Mike1
Climb under the truck and look at the vent line off the side of the filler neck, make sure it's not crushed anywhere.. if it looks good then remove it and blow it out, may have become clogged or had a spider build a nest in it.. We use to just take an air hose and blow the vent line clean but I don't know if these newer trucks can take take the pressure. It could also very well be the solenoid. If you own an OBDII reader that can capture live data, that would go along way in diagnosing the problem.
Old Nov 13, 2019 | 08:01 PM
Djosbun's Avatar
Djosbun
To the OP:
If you can edit your original post, adding punctuation where applicable, I will reply with helpful information. As it stands your post is basically unreadable.
Best Regards,
-- Dave
Old Nov 14, 2019 | 01:27 AM
the_old_ranger
Originally Posted by Djosbun
To the OP:
Best Regards,
-- Dave
You de English techer round hear?
Old Nov 14, 2019 | 06:49 AM
Mark G1's Avatar
Mark G1
To the OP:
Best Regards,
-- Dave
I recently purchased an 09 F250 Super Duty V10 out of Canada through a dealership in North Seattle. I got a great deal on the truck and I really love it. My intentions upon purchasing it was to tow a small rubber track excavator that I have as my 09 Platinum 150 would just get worn out doing that. With that said two issues have emerged, check engine lightwithin the first 300 miles and a code p0442 small evap leak. Upon seeing that I YouTube some videos. The truck being out of Canada the fuel cap was Rusty, everything's Rusty not bad Rusty just rusty. So with that I cleaned the cap, clean the filler neck, cleared the code and the code came back. I ordered a new cap from my Ford dealer and they wanted to sell me an Evap solenoid valve and said that's common among those trucks. I checked around on the web and the're like 50 or 60 bucks. They wanted a hundred and ten. That said, the other thing I've noticed is that I can't put fuel in that truck in 3 to 5 minutes. It's 20 minutes at the pump. It just keeps clicking off and off no matter where I have the nozzle in the tank. The service guy at the dealership said well that's a problem with those solenoids. Any help on sorting this out because I don't have the money right now to go to the dealer with it nor would I I like to do my own work but this is a new beast for me. Thanks in advance. Johnny.
Better?
The Super Duty hard to fill is a known issue. There are several posts about it and fixes for it on this forum. My 2007 F250 has this problem and while I intend to address it at some point I did find a bypass link online that works when filling.
https://www.ford-trucks.com/forums/1...-overhaul.html
https://www.ford-trucks.com/forums/1...-solution.html
Old Nov 14, 2019 | 07:03 AM
NoelCT's Avatar
NoelCT
I had a similar problem with '06 5.4. I dropped spare tire, removed evap plastic tank and associated hoses. I rigged a 1/4" hydraulic tubing to blow nozzle off of compressed air. I blew the living, u no wat, out of all evap components. Then I connected a 2' length of hose to evap inlet and ran it to a high and dry location under bed. It all worked for me. This is probably 2 hours start to finish, tops.
It's also a good time to grease spare hanger cable and inspect tire.
Good luck, Noel.
P.S. Yes, you're first post comes off as a block of words. No English teacher here but suggest that you take your time writing, and re-read, so people can understand your issue.
Old Nov 17, 2019 | 05:40 AM
Bugzilla46310's Avatar
Bugzilla46310
Also a punctuation problem. Twelve lines a one period. One of the better run on sentences I've seen!
Hombre427
2009 - 2014 F150
Aug 14, 2019 02:39 PM
Sirgranticus
Feb 29, 2016 02:11 PM
bigunit54
May 19, 2013 10:45 PM
lincolnboy73
Aug 31, 2010 06:56 AM
motordude0616
Aug 23, 2002 02:09 PM
