Sponsored by: Real Truck
Steering Pull
Old Nov 12, 2019 | 06:45 AM
gwarrick's Avatar
gwarrick
Steering Pull
My 2013 F-350 SWR pulls to the left after I hit a curb.
To a void an accident, I hit a 18” curb with my passenger side going about 30mph. It hit hard enough to break the passenger rear axle block and un-center the rear axle. I replaced that and took it in for an alignment. Shop told me I needed tie rods, which I replaced and return for the alignment. Shop told me the frame was twisted. Took to a frame shop, they said frame was perfect to realign at a different shop. Dealership shop told me alignment was good but I needed new tires. Replaced the tires and rims from another F350 and still pulling left.
Any ideas? I’ve got the results from two different alignment shops, both showing a good alignment. It’s back at the dealership shop but they can’t find anything wrong. Any ideas besides a gas can and a match? Thanks
Old Nov 12, 2019 | 07:57 AM
Juneaudave's Avatar
Juneaudave
Is it pulling to the left during braking? Or pulling to the left all the time?
Old Nov 12, 2019 | 08:05 AM
seville009's Avatar
seville009
keeping in mind that I’m no mechanic, is it possible that the replacement real axle is off center a bit still, or not installed correctly? if so, maybe that would make the front end feel like it’s being pulled by the rear.
Old Nov 12, 2019 | 08:37 AM
gwarrick's Avatar
gwarrick
It’s constantly pulling left, no difference when braking, accelerating or coasting.
The rear axle blocks have a raised dowel to center under the leaf spring. Would be pretty hard to get wrong but I ask the shop.
Old Nov 13, 2019 | 11:14 AM
the_old_ranger's Avatar
the_old_ranger
Was it a four wheel alignment? When I couldn't get a pull worked out I always rotated tires side to side never hurts to try. A perfect alingment can still have a pull and many times it's a tire even though your tires are new.
Steve Hinson
Tennessee Chapter
Jun 14, 2016 04:57 PM
Eddillard79
Dec 14, 2014 08:50 AM
oldbluebronco
1978 - 1996 Big Bronco
17
Apr 16, 2009 06:37 PM
nytewriter
1997 - 2003 F150
Aug 28, 2008 11:53 PM
imlowr2
Aug 14, 2007 11:16 PM
