Rattle Fixed...
Old Nov 10, 2019 | 11:21 PM
stangman68inftc's Avatar
stangman68inftc
Rattle Fixed...
So I have skipped over many posts titled things like "Horrible Door Rattle" as I never had this issue before. However, after 100 miles in 4wd on snowy, muddy, rocky, bumpy, and steep roads in the Colorado high country over the previous week, my truck developed a rattle coming from what I thought was the lower driver door area. It drove me crazy for a couple hundred miles so I started trying to find the culprit. Turns out it was my emergency brake pedal. The bolt (10mm I think) going through the assembly had come loose and it would rattle over every slight bump. I tightened it up and no more rattle. Thought I'd share in case someone else runs until it.
Old Nov 11, 2019 | 04:44 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM
I’ll check my E brake.
My 19 F350 176” SRW has a light rattle resonance sound while stopped in gear.
It sounds like a thin metal shield is loose around the drivers floorboard area ?
i can slightly increase eng rpm & it goes away.
Thanks for your post.
Old Nov 11, 2019 | 05:28 AM
Minniehill2's Avatar
Minniehill2
Great share!
Old Nov 11, 2019 | 06:44 AM
stangman68inftc
It was easy to tell it was loose when the e brake is off. Just try to move it side to side and see if there's any play. When it was engaged, it had enough tension that you couldn't really move it even though the bolt was loose.
Old Nov 11, 2019 | 04:12 PM
honda250xtitan's Avatar
honda250xtitan
heat shield?
JohnyWalker
Jun 10, 2016 05:54 PM
zimm
Oct 29, 2014 12:38 PM
UPSRACINGFAN
May 18, 2009 12:21 PM
calzone
1978 - 1996 Big Bronco
23
Aug 30, 2006 11:20 AM
magnumktm
May 7, 2003 03:14 PM
