Tire Rubbing Issue
Old Nov 10, 2019 | 08:26 PM
jnagel412's Avatar
jnagel412
Tire Rubbing Issue
Hi all! Just bought a 1963 F100 stepside and couldn’t be more excited. After driving it a bit, I have noticed the pitman arm / tie rod connection is rubbing the inside of my driver front tire when turned hard to the left. It has disc brakes on it, with 235/75/R16 cragar wheels (not sure on offset). Any ideas on why this is rubbing? Wrong tire size? You’re help is appreciated.
Jon
Old Nov 10, 2019 | 09:42 PM
Christmas's Avatar
Christmas
There should be adjusters on the spindle carrier that will limit the turning radius, depending on the year the front end is from.
Old Nov 10, 2019 | 10:33 PM
cosmofennema's Avatar
cosmofennema
You've got non-standard brakes and non-standard wheels/tires.
This is very likely why it's rubbing. Either change the wheels/tires, or adjust as suggested, though your turning radius will increase.
Old Nov 10, 2019 | 10:52 PM
Christmas's Avatar
Christmas
I think you meant decrease.
Old Nov 10, 2019 | 11:43 PM
cosmofennema
No. If he limits the amount the wheels turn, the turning radius will increase.
'Turning radius' refers to the amount of space required to turn the truck.
Old Nov 11, 2019 | 12:18 AM
Christmas's Avatar
Christmas
You are right. I did not equate it to a larger circle, but less wheel travel side to side.
Old Nov 11, 2019 | 06:09 AM
jnagel412's Avatar
jnagel412
How is the spindle carrier adjusted?
Old Nov 11, 2019 | 09:29 AM
jnagel412's Avatar
jnagel412
What about a wheel spacer? I don't have any experience with them, but they would be an easy solution rather than limiting my steering.
Old Nov 11, 2019 | 09:55 AM
oldracerjones's Avatar
oldracerjones
Wheel spacer moves the wheel and tire out but be careful, do not use one over 3/4" or you could risk damage to the truck. I would not use them for heavy highway driving.
Old Nov 11, 2019 | 10:30 AM
jnagel412's Avatar
jnagel412
My thought behind the wheel spacer was to move the wheel out. I was thinking 1" but not sure if that would be enough to stop the rubbing.
Old Nov 11, 2019 | 01:37 PM
cosmofennema
A wheel spacer is, IMHO, a very bad idea. It puts excessive loads on the studs, possibly leading to breakage.
It alters the geometry, leading to weird and possibly harder steering. Also the altered geometry can cause odd feedback over bumps and on slipperly pavement.
But, it IS your truck, proceed as you see fit.
Old Nov 11, 2019 | 01:42 PM
jnagel412's Avatar
jnagel412
I appreciate the feedback. Seems like the best options are changing the wheels or adjusting the steering.
How is the steering stops adjusted on these trucks?
Old Nov 11, 2019 | 01:43 PM
cosmofennema
It's a bolt, with a locknut.
Old Nov 11, 2019 | 01:53 PM
jnagel412's Avatar
jnagel412
I appreciate the quick reply. I will give it a shot tonight and hopefully can figure this out.
Old Nov 12, 2019 | 07:44 PM
jnagel412's Avatar
jnagel412
I got the steering stops adjusted. The unadjusted side gets two full turns and the newly adjusted side gets approximately 1.75 turns with no rubbing.
Thanks to all for the input, it is greatly appreciated!
