Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
New tank
Old Nov 8, 2019 | 11:37 PM
jmtbiggin's Avatar
jmtbiggin
New tank
The 1960 F600 is getting an upgrade. Salvaged this clean 50g tank and brackets off an L series 6 wheeler. Both brackets and tank have the Ford emblem and their part numbers. Maybe the sending unit will jive with my gauge, fingers crossed. Looking forward to sliding the seat back alittle further.
Notice the safety catch bar up to stop bed coming down. The hydraulics haver never budged, but I am to chicken 🐔 to work under there with out it
Old Nov 11, 2019 | 07:37 PM
85e150's Avatar
85e150
Can you fill that with the bed down?
Old Nov 12, 2019 | 11:44 AM
jmtbiggin's Avatar
jmtbiggin
Yes I can fill it just fine, the sending unit and my gauge work together fine
Old Nov 12, 2019 | 02:12 PM
85e150's Avatar
85e150
Excellent. My dad's '58 had a round 40 gallon in that spot. Is that your only tank now? The '58 had a manual valve sticking out in the footwell below the driver. Sender on the seat tank only. You'd run the side tank out, then you'd have the gauge for the seat tank to clue you on refueling. Made for a nervous moment or two reaching down for that switch at speed when the side tank went dry.
Old Nov 12, 2019 | 05:42 PM
jmtbiggin's Avatar
jmtbiggin
Still running off the OEM behind the seat, it will go away after side tank is up and running
Old Nov 12, 2019 | 06:08 PM
Spirit of '76's Avatar
Spirit of '76
Looks good. I have one just like it on my F600.
Is yours a gas job
Old Nov 12, 2019 | 08:53 PM
jmtbiggin's Avatar
jmtbiggin
Yessir, 292
Old Nov 13, 2019 | 09:50 AM
Destroked 450's Avatar
Destroked 450
Even with good hydraulics one should never work under a raised bed without it being blocked
I have the same hoist for my 93 F-800 diesel, it's fuel tanks also look much like the one you have.
Old Nov 24, 2019 | 11:55 AM
F350 1990's Avatar
F350 1990
Have similar setups and would add that it's important to replace the rubber "padding" under the straps/under the tank on the two support brackets --- seems to be a common area where friction/wear causes holes in these tanks..............readily available in 1/4" or so thickness, various widths on rolls.....cheap insurance!
BTW -- never trust those old hydraulics, block it for safety.
R/S85
Nov 2, 2018 12:40 PM
86F150302
Jul 4, 2008 11:42 AM
CowboyUp1387
Dec 8, 2005 08:31 PM
wolf189
16
Dec 16, 2001 10:33 PM
